Remove Edge for Service?
Old May 19, 2009 | 08:24 PM
Smokin Lariat's Avatar
I'm taking my 06 Lariat 4x4 in for service tomorrow. Dealer is replacing the IWE solenoid and the hubs if damaged. I have an Edge Evolution programmer running on the performance level. Should I remove this and return the programming to stock before taking it to the dealer???
They tell me the repair is covered under my Ford ESP so i dont want to give any excuses for them to change their minds.
Old May 19, 2009 | 08:26 PM
NoLongerJeepin's Avatar
Yeah I would definitely remove it and set it back to stock.
My truck was in for work (out of warranty) and they still grilled me over whether or not I had tuning. They didn't want to work on the truck if it did
Old May 19, 2009 | 08:29 PM
BrizzleOrizzle's Avatar
yes take it out. it could void the warranty.
STXbucko's Avatar
Since the repair your having done has nothing to do with the PCM (what the EDGE tuner changes), it should not matter, but I'd do it just to be safe. These tuners save your stock mapping, so it should only take a minute (or less) to set it back to stock.
Is your's removeable (to "hide" the evidence), or is it mounted in one of those housings on the left dash?
The dealership could always claim that you were "rough" with your vehicle (by seeing the EDGE tuner), so this would be playing it safe.
Old May 19, 2009 | 08:52 PM
Mine is in one of those left side of dash housings but I think I can remove it pretty easily. Pain will be pulling the cable out - not hard to do but if I left it in there's always a chance they'd find it.
Old May 19, 2009 | 09:43 PM
bdholsin's Avatar
Take it out for no other reason than some sticky fingered lowlife may decide he wants an Edge more than you do. Since it is so easy to install and take out you may as well give yourself piece of mind and remove it.
Old May 19, 2009 | 09:46 PM
Shanks12's Avatar
yeah and if you take it out make sure you do return it back to stock dont just unplug it... My boss took in his bullydog programmed diesel and didnt return it to stock, and then they changed the PCM code and so his programmer wouldn't work till it was reset, a bit of a hassle... so you might as well do it for piece of mind
Old May 19, 2009 | 10:03 PM
Absolutely. Always return it to stock before you take it in, even if there is no warranty and you don't remove the monitor. They have been known to do people a "favor" and relash the PCM.
Old May 19, 2009 | 10:07 PM
rednoved's Avatar
Take it out!
Old May 19, 2009 | 10:40 PM
pylda's Avatar
What if you set back to stock and remove and they do reflash the PCM. Can you still reinstall the edge/gryphon without any problems?
Old May 19, 2009 | 10:45 PM
Only if the new calabration is one of the many already in the unit. Otherwise, you may have to update the unit to download the calibration.
Old May 19, 2009 | 11:08 PM
pylda's Avatar
So would you advise to also insert in the nifty "do not reflash, consult owner" plug?
Old May 19, 2009 | 11:12 PM
No, because that tells them you have a tune and becuase the have to pulg in for diagnosis.
Old May 20, 2009 | 09:03 AM
pylda's Avatar
So basically...return to stock, remove all visual evidence of the gryphon/edge, plug everything back in when I get home and try to program. And hope they didnt reflash.
Would you also do this if you were taking the truck in to the dealership for an oil change? I got 5-years of changes for free.
Old May 20, 2009 | 09:18 AM
There are two different issues here.
One, do you care if they see that you have a tuner and might disallow a warranty claim simply because you have a tuner? If so, then remove all evidence.
Two, if they will be doing anything other than an oil change, I would return it to stock.
I no longer have a warranty, so I leave my unit in but if they are going to do anything other than an oil change, I return it to stock, just to be safe. You never know what they might decide to do. I also tell the service manager to write on the ticket, "do not reflash without discussing with the customer".
