Doors Creaking
Old May 8, 2009 | 11:43 PM
HiVoltage14.4's Avatar
Doors Creaking
My driver and passenger doors will creak while going over any little bumps in the road. Its kinda loud sometimes. Is there a fix I heard it was a known problem.
Old Nov 10, 2009 | 10:09 PM
enggass's Avatar
I think I have the same thing starting... Anyone have any ideas?
Old Nov 10, 2009 | 10:25 PM
Have you tried some XL-5 Multi-Purpose Grease from FCSD Chemicals and Lubricants?
You can get it from your local Ford Parts store under the Ford Part Number: XL-5 or you can alternatively get the XG-4 (FAD).
The XL-5 is a 11.5 oz spray can of it... this one I highly recommend because it really gets the grease in the door jams well. The XG-4 (FAD) comes in a 4 oz caulker's tube and great for lubricating seat tracks for example where the spray from the XL-5 might ruin the carpeting or other surfaces.
It's for:
*Outstanding general-purpose grease for use on metal surfaces such as door hinges, seat tracks and deck lid hinges
*Continues to lubricate long after application
*Not affected by wide temperature operating ranges
*Amber color
Or the alternative (non-Ford/Motorcraft) is standard White Lithium grease available at any parts store, hardware store, or pretty much any place where lube grease is sold.
Old Nov 11, 2009 | 07:53 AM
kingfish51's Avatar
If it is creaking while closed, it is the door and rubber rubbing a bit. Get some silicone spray used to keep auto weather stripping soft and pliable. Use that on the rubber.
Old Nov 11, 2009 | 01:36 PM
enggass's Avatar
Yes exactly... at least I think it is the door because at times I can replicate the sound by pulling on the door. It is a low tone creak that happens going over small bumps or sometimes turning. I will try that. Thanks!
