LED's all around installed
Old May 20, 2009 | 07:43 PM
  #61
dadrett's Avatar
Originally Posted by alomar
No, no red, getting the cargo lights, not for the brake light portion yet.
Sorry, U'r opening says, "Here is my question in reguards to the third brake light."
Old May 20, 2009 | 08:29 PM
  #62
alomar's Avatar
Its all the same unit, technicalities, technicalities
Old May 20, 2009 | 08:49 PM
  #63
dadrett's Avatar
Originally Posted by blackjack8900
Finally got some pictures of my LED's I got installed.
Pics are crap but the best I could do with my great knowledge of camera's .
At least U'r able to post pics. Posting rules: You may not post attachments. Is this age discrimination because I'm an old fart? How does one go about getting permission to add attachments?
05-22-09 Well, thanks to nudge from Fabian06SC, I figured a way to post pics. Not sure it’s the right way, but it works.
Old May 21, 2009 | 09:53 AM
  #64
STXbucko's Avatar
Originally Posted by dadrett
If I understand U'r post at above link, U did not use resistors at rear lights & as result had rapid flash. U could use resistors in front by attaching to simple flat brackets & attach brackets with existing bolts. This puts resistors out in open & heat is no problem. U can also mount brackets out in open under rear of truck. U'r LED high-mount unit may not have had resistor load. This & no load at rears results in no cruise. U don't have to do any soldering. Use quick-splice connectors & make "pig-tails" to plug into resistors. I have mentioned in several posts about being denied attachments. No member has offered any help or explanation. I've tried to contact the "forum" folks but all I get is an automated reply that they received my request. Saying goes, "A picture is worth 1000 words." & some of what I'm saying would be clearer with pics.
Someone please, how about some help with posting pics.
My flashers worked fine with the LED bulb (3157's), but only because I installed an LED flasher. I don't like cutting or splicing into factory harneses unless it's absolutly nessesary. Using an LED flasher allows both LED or conventional bulbs to work in the turn signal circuit. If you install load resisters, you cannot use a regular bulb, as it will flash very slow, if at all.
My other stement was to the brake lame portion of the LED 3157 bulb. I would not want to install a load resister in this circuit either. I'd rather pay for a LED tail light assemply, with this "load" built into their circuit board, so that my cruise will work.
Old May 21, 2009 | 09:28 PM
  #65
STONED150's Avatar
I just ordered some for my trucks.
Old May 22, 2009 | 12:40 AM
  #66
alomar's Avatar
FWIW, anyone who orders from v-leds.com use coupon code commander15 I believe its 15% off. I did it last night and it worked, covered my shipping. Just a heads up.
