leveling question....
Old Apr 30, 2009 | 09:54 PM
triton5.4FX4's Avatar
What is recommended more, a 2" AS leveling kit or a 2.5". Is there really a difference? Any suggestions on where to find them for a good price? Thanks.
Old Apr 30, 2009 | 10:01 PM
Mr.C's Avatar
2" spacers made mine set level. Auto Spring seem to be what every one uses. Here the E Bay link.
AUTO SPRING AS 2004-08 FORD F-150 2" Front Lift Kit
http://cgi.ebay.com/ebaymotors/AUTO-...1%7C240%3A1318
Old Apr 30, 2009 | 10:12 PM
NoLongerJeepin's Avatar
If you want your truck to sit dead level go with the 2.5" leveling kit. The 2.5" kit with cause the front to be slightly higher on the 06-08 trucks because they have less rake from the factory. If you want a little rake, go with the 2" kit.
Old May 1, 2009 | 02:53 AM
Tylus's Avatar
go with the 2".
a 2.5" makes the nose just a hair too high. and the 07+ guys are even worse. sometimes a 2" is even too much on them.
but yeah, the Autosprings is the best IMO of all the brands out there. I have the 2.5" up front, and the 3" rear blocks sitting in my garage waiting to be installed
Old May 1, 2009 | 06:46 AM
mhockey9090's Avatar
Yeah AS got mine for $90 they usually are all over ebay and mine was a 2" and it sits level
Old May 1, 2009 | 09:22 AM
rms8's Avatar
$90? You must have purchased yours some time ago, yes?
I paid $65 SHIPPED for my 2" AS.
The 2" spacer actually made my front sit 1/2" higher than the rear. I corrected this with a new set of Firestone Ride Rite airbags.
I was going to have to get them anyway since I race during the season and the AS WILL MAKE THE REAR END SAG when towing. This is why the F150 has a rake from the factory, to prevent rear end sag when towing.
Old May 1, 2009 | 12:11 PM
After the leveling kit, do you have to get the truck realigned?
Old May 1, 2009 | 12:26 PM
Tylus's Avatar
yes
if not, your tires will get eaten up
Old May 1, 2009 | 04:09 PM
ok thanks guys
Old May 1, 2009 | 05:25 PM
dbhost's Avatar
I have the 2.5" on mine, and it actually still sits with a SLIGHT rake.
Old May 1, 2009 | 06:41 PM
BLACKOUT FX4's Avatar
it all depends on what wheel/tire setup you plan on using. if rubbing isnt going to be an issue due to tire size, i would go with the 2" kit.
i have the 2.5" kit and i need to add a 3" block in the rear because it looks like the rear is too low.. it actually sits perfectly level but still looks like the front is a little bit higher..
Old May 1, 2009 | 08:31 PM
5.4FX4's Avatar
Nice user name, very creative!
Old May 1, 2009 | 09:16 PM
2004f1505.4x4's Avatar
Got a hell bent 2.5 in mine and it sits level
Old May 1, 2009 | 09:30 PM
The '04's had a lot of factory rake and a 2 1/2" kit seem's to work OK.
Old May 1, 2009 | 09:47 PM
I have Bilstein leveling struts ( 2" ) but my '04 is leveled near perfect. The rear end sits exactly 1/4" higher, hardly noticeable, and looks great. Most swear by the 2.5" kits for '04 - '05s with the larger rear leafs, but 2" does the job just as well imo.
