Power Rear Window
Old Apr 26, 2009 | 11:28 AM
Drunkonjack's Avatar
Power Rear Window
My power rear window won't open when I use the switch to power it open. It worked when I tested it when I purchased it.
This is the rear window on my Super Crew not the pasenger windows.
Now with nicer weather I tried it and it failed to open.
Any Ideas ?
Old Apr 26, 2009 | 11:39 AM
countyboy04's Avatar
Mine sticks from time to time. I just hit the switch a couple of times and it eventually opens.
Old Apr 26, 2009 | 04:11 PM
Tried beating on the window to break it loose and rocked the switch back and forth but it still won't work. I would'nt think it has it's own fuse as everything else seems to be working.
I'll check fuses.
Old Apr 26, 2009 | 04:24 PM
yetti96's Avatar
Happened on my grandmother's old Screw. The window was "fixed" under warranty, basically, they greased the cable and just hit the switch until it worked with a little help. Once you get it working, use it often to keep it lubed.
