Wrench...
Getting a new short block. Engine seized, couldn't crank it at the dealer. They tried to hand crank it, wouldn't budge either way. I assume a rod or something bent to hell when they tried to start it. Yeah me. :o
Yep, covered under the extended warranty for the 05 5.4 injectors. I have a thread about it down the list, P0175.
I'm going to say this is not an injector problem. I have the same issue when WOT in cold temps and i know 100% it's the drive-by-wire pedal sensors.
I'm going to be replacing both the throttle body and the dbw pedal just to be on the safe side.
I'm sure you'd have to return to stock and then get new tunes since the PCM strategy code will be changed with the calibration reflash.
