Bilstein 5100's Installed
Old Apr 2, 2009 | 11:19 AM
fx4 for life 79's Avatar
Originally Posted by Tornadom
Sound like a great shock! I need new shocks on my truck, as well as new tires. I had planned on 36" or 37" tires, with coilovers when these tires were shot, but the guy I sold it to (and bought it back from) ignored the alignment and ruined these tires. I figured I could get the Bilstein leveling shock and set them up higher, then get my taller tires after all (I have a Pro Comp lift that uses stock length shocks). I can always buy my coilovers down the road. Any pictures?
much cheaper than getting coilovers which means more money for tires
Old Apr 7, 2009 | 04:15 PM
Maniac01's Avatar
Check out my 5100's Album in my profile to see some pictures of these..
Old Apr 8, 2009 | 11:17 PM
dirk upson's Avatar
how long should it take the dealership to install the front 5100s on my 08'?
Old Apr 9, 2009 | 09:25 AM
05supercrew's Avatar
About 1 hr. or so. It took my dealer 1hr 20 minutes to remove my 2'' Autosprings and install my Bilstein 2'' 5100s.
Old Apr 9, 2009 | 12:42 PM
dirk upson's Avatar
thank you............
Old Apr 9, 2009 | 03:05 PM
No problem
Old Apr 9, 2009 | 08:23 PM
dirk upson's Avatar
i put the clip on the lower of the two because i wanted it to be stock, took it to the dealership to have them install the fronts. now the truck is nose high, not stock. is the stock height setting the lower clip or the higher clip. i was told the lower. they said they didn't change anything. help............
Old Apr 9, 2009 | 09:34 PM
last5oh_302's Avatar
The higher clip is for a 2" raise. The bottom clip is for stock, or the 0" setting.
I have mine on the higher groove for the 2" level.
Old Apr 9, 2009 | 09:48 PM
dirk upson's Avatar
i think they put a part back on upside down. where the coil sits on looks different than your picture.
Old Apr 9, 2009 | 09:58 PM
Post a picture of it.
Old Apr 9, 2009 | 10:33 PM
dirk upson's Avatar
where the coil rests is completely different than yours, it is upside down. your picture saved me a lot of money. i was going to pay to have it taken apart. they put it back together wrong, they get to pay it.......
Old Apr 14, 2009 | 01:22 PM
Maniac01's Avatar
Gotta love this site for that reason alone!
Old Apr 14, 2009 | 10:15 PM
Looks good!
Old May 29, 2009 | 12:23 PM
Hawgdriver's Avatar
Guys please explain...My '04 FX4 currently has the leveling kit up front. I am due for new shocks and am looking for the best route to go. Are guys saying the Bilstein 5100 adjustable shocks are the best way to go and get rid of the leveling block up front? What is the best replance shock if you keep the block? Bilstein 5100's set to stock? Can someone please give me the best setup for ride quality to go with?
Thanks a ton!
