How much should I look to spend?
Old Mar 27, 2009 | 01:40 PM
bigdog87's Avatar
I want to get
1. 6" Fabtech=2000 Installed
2. 20" chrome wheels with 35" Toyo MT(Mounted installed 2600)
3. 4:10 or 4:56 Gears=700
4. Gryphon Tuner=440.
5740, Total. Does that sound around right?
How much do you thnk I'm looking at for all of this? I put some general $ up, help me out.
Old Mar 27, 2009 | 01:50 PM
JesseRohr's Avatar
The wheels and tires and gears is going to be tough.
Old Mar 27, 2009 | 01:57 PM
bigdog87's Avatar
I only assumed 700 for gears because I am 2wd, so one set of gears?
Wheels and tires, I have a kind of connection with a place online, that mounts balances, and sends them to you mounted and balanced(gotta figure out what wheels I want though)
Edit: I can get 20x10 Chrome Monsters on 35x12.5R20 Nitto Mud Grapplers mounted, balanced to my door for 2598.
Old Mar 27, 2009 | 02:00 PM
ATOM's Avatar
i would say more to 6g prices are going up on stuff, i know some of the deals i got last year are now impossible to find.
Old Mar 27, 2009 | 02:01 PM
bigdog87's Avatar
Basically give or take 2-300 dollars?
Old Mar 27, 2009 | 02:29 PM
wxscpo's Avatar
I'd say you're probably right in the ballpark on what you can expect to pay. I had my 2WD lifted two years ago and paid less than $4500 for my lift, wheels, and tires. I had 18" Helo Maxx 6 wheels and Pro Comp Xtreme AT's though your wheel/tire combo is costing a little more than mine did. Also make sure since you're a 2WD that you get the Fabtech 5" lift block for the rear or you'll be sitting lower in the rear. I also had shock boots added to the rear shocks as well, those ran less than $10 for the pair.
I had a set of Yukon 4.56's installed about 9 months after lifting and paid a little less than $800, but out here in Hawaii things tend to run a little on the more expensive side so $700 for you is probably about right.
Make sure you come back in and post up some pics of the truck when it's done.
Old Mar 27, 2009 | 02:31 PM
bigdog87's Avatar
Ah sweet! Thanks man. Hey, you have the monsters chrome, i'm looking at those. What size are they, do you like them?
I'll post around 5000 pictures haha
Old Mar 27, 2009 | 02:39 PM
wxscpo's Avatar
I really like them, but have one issue. The center portion that says XD Series came off on one of the wheels one day. I got out of my truck and just noticed it was gone. Looked at the other 3 and saw that they were barely on there with a small dab of glue. I ended up pulling them off and am now in the process of looking to replace them. So if you get the Monsters I'd recommend reapplying them yourself, unless it was just my set that came that way.
They are 18x9 with 35x12.50 Pro Comp MT's
Old Mar 27, 2009 | 02:42 PM
bigdog87's Avatar
Damn, that sucks. Those look really good, are they really shiny? I want them to shine like helloo
Old Mar 27, 2009 | 02:47 PM
ATOM's Avatar
fabtech prices went up i don't know where you can get it for 2g installed but if you can good. rims and tires depends on what 20's you go with, tires are around 1400ish. so you are close
Old Mar 27, 2009 | 02:52 PM
bigdog87's Avatar
Yeah, I've heard mixed things but everything I've seen Fabtech is still less expensive than Pro Comp.
Old Mar 27, 2009 | 02:55 PM
ATOM's Avatar
maybe it's different for you 2 wheel guys, but usually pro comp is cheaper than fabtech
Old Mar 27, 2009 | 02:59 PM
bigdog87's Avatar
Freaking 2wd
