Please help!!! Squeeky something!? About to get a dodge
I have this really annoying squeek and i have no idea what it is. It sounds like it's coming from the drivers side dashboard. I have brought to the dealership twice. The first time they had it for 4 hours and they thought it was fixed (said they tightened up a bunch of stuff under my hood and removed my stinger from the quick hitch). Second time they were a little more thorough. They kept it for 4 days and took the entire dash apart. The service rider claimed that it only did it in the mornings... but in fact it does it when I drove over a serious of bumps. It doesn't have to be big bumps just enough to make the tires shake. So if anyone has any advice or experienced this I sure would appreciate any help. I can not stand squeeks driving down the road and its making me a new truck... preferably a dodge
Yeah that's the problem with my ford right now. Don't get me wrong I love the way my truck looks and everything... but this squeek has got me so ticked off that I don't even like driving it anymore.
As for your issue, I had a really bad squeak form the passenger dash area. I noticed that my A pillar on the drivers side was loose. Look at the bottom of the A pillar where it meets the dash, mine was sitting funny, I pushed it back in place while tightening up the two bolts on the pillar and I have not had a squeak from that location since. Also push in your ashtray and hold it when you hear the squeak. If the noise stops do a search for ashtray rattle. Hopefully one of those two helps you out.
check that your sway bar links are tight
a loose link will allow a clunk and squeaky noise
other than that, go through every body panel in the truck and make sure they are all tight
I had the same sqeak in my 08 Ford on the driver's side dash. I was going to do some searching to see if I could find the solution. I bought and edge evo and when I installed the pod, it tightened up the dash and there is no more squeak. Not sure how I would have fixed it otherwise.
Why downgrade to a Dodge... Atleast go Chevy. A Chevy will last atleast as long as Fords will. Dodges make more noises and are more flimsey than the other trucks, use the most gas, and have s**t trannys, but w/e your preference is its your money.
It's your exhaust system.
My recommendation:
1. Take it to a reputable exhaust shop
2. Have them cut out the y pipe
3. Run 2.5-3" true pipes back to a Magnaflow DI/DO magnaflow stainless muffler.
4. Route the tailpipes out the side (left/right or right/right) or rear left right.
5. Add chrome over stainless tailpipes
That should solve that squeeky noise.
My recommendation:
