Front Differential Bracket Repair kit
Has anyone had to have this kit installed? The manufacturer's design of the original front differential bracket is flawed on the 2006 F-150. It allows for torque from the front differential to pull back on the left side of the bracket thus eventually tearing the bracket from the frame. When this happens, your 4x4 is now a 2 wheel drive truck. This happened to my truck and the repair kit is $633.35 and the TBS report does not inform you of the amount of labor involved. You must purchase the kit first. Ford knows this is a manufacture defect and will take no responsibility outside of the original manufacture warranty.
Any thoughts on this from anyone? Any help or constructive information would be greatly appreciated.
I don't know if it affects any other years, I do know that if Ford has a repair kit, then they know that this is an existing problem that they should take responsibility for even if it happens outside of the manufacture warranty.
Never heard of it before?
Just figured out I have this issue too. 4 wheel is hopping under load because left bracket is broken off the frame. Figured it out after I replaced both wheel hubs and IWEs of course. Can't find a picture of the weld brackets to fix. Not sure how I would justify the crazy cost either, not including the welding. Any ideas out there, other than to move south with my now 2wd truck?
