Will this tires fit 05 f-150?
I had these rims and tires on my 4x4 04 eddie bauer expedition. Will they fit a 05 f-150? 305/50 R20 is the tire size. Cant remmeber what the offset is for them is.
not the Expy rims, but the Navi rims have the smaller center section on the rims.
Expy rims from 2003+ are interchangeable with the 2004+ F-150.
I'd test fit them to make sure since they have 305 width rubber though. that's roughly 12" wide and depending on the offset, it may be kinda close to the upper ball joint. luckily the 20" rim kinda negates that
The expy and navi are basically the same vehicle, so the wheel fitment issue applies to both. Also, the smaller sized center hub of expy/navi wheels not fitting on 150's only applies to OEM 17" and 18" wheels, the OEM 20's do not have this issue so therefore are interchangable.
The wheels the OP has are aftermarket, so they will defintely fit. They look similar to these.
http://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialP artNumber=6042863C&wheelMake=Granite+Alloy&wheelMo del=GA4.6&wheelFinish=Chrome+Plated&showRear=no&au toMake=Ford&autoModel=F150+FX4+Super+Cab+4wd&autoY ear=2007&autoModClar=&filterSize=20&filterFinish=C hrome%2FBright&filterSpecial=false&filterBrand=All &filterNew=All&sort=Brand
