gears, rev limiter, etc.
How can I know what gears came in my 2wd 2004 F150 XLT 5.4l 3v? I just bought an Edge Evo tuner and need to know some things to set it up properly. I'm looking to setup the towing performance tune and correct my speedo. I had 17" factory crap-chrome wheels and just put on 18" FX4 wheels with Goodyear A/Ts. I setup the Edge for the tire size but my speedo is 3-4mph too fast, before the edge it was 3-4 mph to slow. I set it up for 3.73 gears but now sure if I have the 3.55s instead. I also need to know what I need to set the rev limit at and the WOT shift points. I've tried searching but I'm not having very much luck. Any help would be appreciated.
The Continentals are 30.05" in diameter.
The Goodyears are 32.07" in diameter.
That's a 7% difference in tire size, so your speed will be off. Make sure to adjust your speedometer setting up by 6.3%.
