325/50/R22 Will They Fit With Leveling Kit
Old Feb 26, 2009 | 03:13 PM
agadawg1717's Avatar
Question 325/50/R22 Will They Fit With Leveling Kit
Just to start off yes my truck is 2wd and I know I'll get **** from some of you guys, but I tried the lowered truck deal and its not for me.
I have plans now to remove my 2.5'' lowering shackles and reinstall the factory ones and then put a leveling kit on the front. 2 Questions?
What size leveling kit do I need?
Can I fit 325/50/22's on my wheels that are 20x9.50 and 30mm offset with just a leveling kit? If not what is the biggest tire I can fit that is made in a all-terrain? Or should I ditch the 22''s and go to 20''s since there are more tires available?
Old Feb 26, 2009 | 03:21 PM
ATOM's Avatar
i doubt it, if your truck was 4x4 i'd say yes. the norm is a 33 on a 2wd and a 4x4 can get away with 35's
Old Feb 26, 2009 | 03:28 PM
So what size would that be for in metric for a 33"?
Old Feb 26, 2009 | 04:55 PM
ATOM's Avatar
305/45R22 32.80" x 12.00"
Old Feb 26, 2009 | 08:36 PM
BLACKOUT FX4's Avatar
i dont think 325/50/22 will fit but Nitto makes a 33" terra grappler in for a 22" wheel..
285/50/22 will fit no problem with a 2" leveling kit
Old Feb 26, 2009 | 09:54 PM
alexarizpe's Avatar
i also have a 2wd with a leveling kit and at the moment i have 285/70/17 and it does not rub. but today i bought me a set of toyo A/T 305/45/22 (about a 33" tire) they will be on a set of xd hoss wheels. hopefully i can have them mounted some time this weekend and im hoping they wont rub.
Old Feb 27, 2009 | 08:42 AM
Let me know how they work out and post some pics!
Old Feb 27, 2009 | 08:43 AM
If I decided to change to a 20'' stock wheel what is the biggest tire I can fit?
I'm looking at a set of 325/60/20 and wondering if those will fit?
Old Feb 27, 2009 | 09:19 AM
Bigrod330's Avatar
Thats a true 35 tire. Being 4x2 I would think you need more lift than it takes a 4x4 to fit 35s. If you level 2 inch on a 4x2..should fit those 33s ( 305/55 ) no problem?
How much lift does it take a 2wd to get up to the stock size of an FX4? If some one answers this and says 2 inches.....you will need a complete lift to fit the 325/50/22, a 34.8 tire. Here is my FX4 with those tires, but not leveled yet, 2.5 kit on the way. Can NOT drive it this way....one bump in a turn and it would lock up the tire in the wheelwell. Hope this helps you.
https://www.f150online.com/forums/wh...ng-w-pics.html
Old Feb 27, 2009 | 01:30 PM
BGF150's Avatar
usual general rule of thumb is 2wd with leveling kit will fit 33s and a 4wd with leveling kit will fit 35s. but there is exceptions to the rule this guy did fit 35s on his 2wd with only a leveling kit and some trimming to the front bumper, here's the thread link https://www.f150online.com/forums/20...-problemo.html
