Gear change
yes, everyone is getting re-geared when upgrading to 35s.. theres a chart out there just cant find it, but thats with bigger tires. im not sure but it should be the same for you. maybe 4.56s?
i probably should have specified. i have a street truck. 22" rims with 305/40 tires. not 35's by any means. i just havent seen anything on the subject. lots of info for lifted trucks though.
are you keeping the same overall diameter?
or upgrading tire diameter while bumping to the 22" rims?
if keeping the same overall diamter, the change to 4.10 gears will overcome any power loss you have due to the extra weight.
if upping the diameter as well, the 4.10 may/may not help out. It depends on the final tire size. a 4.56 gear is about perfect for 35" tall tires, and a 4.10 set is about right for 33-34" tires
I have 305/40/22's and I changed from 3.55's to 4.30's but wish I had gone with 4.56's. But I am still happy with the 4.30's, they say in a NA application that you really need to go 1 numerical range to notice a big improvement that would mean 3.55 to 4.56 to really notice a difference in the seat of the pants. just my .02
i honestly have no idea what the factory diameter is. i was mostly wondering if anyone has done the change, and if so, the pros and cons of it.
im definitely not putting on offroad tires on a 2wd truck.
plus its lowered.
thanks. thats kinda what i was wondering.
Yeah I definetly wouldn't regear by just bumping up to 22" wheel.....actually I haven't regeared even with the lift and tires on my current truck with 3.55's. But that alone keeps me from going to a 37" tire.
