trans fluid
Old Feb 24, 2009 | 08:15 AM
mav015's Avatar
trans fluid
has anyone changed their trans fluid on there own. Its time for me to do it for my truck. Just wanted to no if its pain is the *** or if its ok. I have an 06 5.4 xlt.
thanks guys
Old Feb 24, 2009 | 09:20 AM
05supercrew's Avatar
I didnt do mine but had it flushed and it made a difference in shifts. Im sure its like any other tranny fluid change.
Old Feb 24, 2009 | 10:37 AM
vtron's Avatar
Check this thread
There's a link to the guide I used. It was pretty easy, just make sure you use the TOP cooler line at the transmission. This is the return line from the trans cooler. If you use the bottom, you'll spray oil everywhere.
Old Feb 24, 2009 | 11:31 AM
mav015's Avatar
thanks guys
Old Feb 25, 2009 | 09:31 PM
mkinttrim's Avatar
I would get it flushed as well, did mine, think it was $150.
Decided to have dealer do it as I have the extended warranty. I was afraid if tranny failed in the future and they found out it wasn't flushed they wouldn't cover it.
Old Feb 25, 2009 | 10:40 PM
yetti96's Avatar
I just dropped my pan and replaced the filter, not a full flush but cheaper and easier.
Old Feb 25, 2009 | 11:15 PM
arrabil's Avatar
Isn't the recommended flush interval at 150,000 miles?
Old Feb 26, 2009 | 12:44 AM
Power Kid's Avatar
I did flush first time, 2nd time drop pan and filter. Problem with with that is you only change @ 30% of your fluid as the rest is in the tq converter. So flush is better. I put in Royal Purple...
Old Feb 26, 2009 | 12:46 AM
RoushF150's Avatar
If you want your tranny to die at 90,000 miles, go for it...
Old Feb 26, 2009 | 12:50 AM
arrabil's Avatar
150,000 miles is what it says in the manual, no?
Old Feb 26, 2009 | 01:03 AM
RoushF150's Avatar
Yes, and it also says 100K on the spark plugs. Ever known a plug that lasts past 60K miles without going south?
Old Feb 26, 2009 | 01:05 AM
Power Kid's Avatar
I did mine @ 130.
RoushF150's Avatar
Originally Posted by Power Kid
I did mine @ 130.
130K? Or 130 miles.
Old Feb 26, 2009 | 01:19 AM
arrabil's Avatar
There is a thread going on right now about people with plugs older than 100K. And yes, I've had two vehicles where I replaced the plugs at the recommended 100K and when I pulled them they didn't look worn out at all.
Smooth shifting is the number one problem with Ford (can't speak about other manufacturers) automatics. And sitting in OD when it shouldn't would be second. The bands always seem to be the weak link. The fluid outlasted the bands and cheap nylon bushings in my previous experience.
