Accident = bent frame - opinion?
Trying to be brief - I was in an accident with my '08 F-150 - one hit was broad side into a car (pulled directly in front of me while doing 55mph) - second hit after the car hit was into a bank.
Beside the cosmetic damage only to the right fender, when I hit the bank is where most of the damage occured.
Sorry - no pics yet.......
On both sides of the front suspension, the upper arms connected to the ball joints are pushed against the struts. The lower a-arm (correct term? where the bottom of the strut is attached) on the driver side - where it is mounted to the frame is bent. Tie rods bent - probably more damage than my un-trained eye is seeing.
What gets me is - when I look at the front of the truck, the tow hook on the passenger site is about 2" higher than the drivers side. When you look at the frame itself it is also higher. Also, you can not open the passenger side doors.
My body guy after a quick look said the frame is definitely bent. The appraiser had a first look at it today, and said just the visible damage is over $5100. He is having the body guy tear the truck down to see what else they can see.
I have the feeling of a screwing coming......I've always been under the impression that if the frame is bent, it is totaled.
My body shop guy (who I trust - been dealing with for 20 years) says that he rarely sees the appraisers total a truck that new - has even seen where they have put an entire new frame under a vehicle.
I don't like this a bit - in my eyes, if the frame is bent, even if they try to straighten it, it will never be the same.
Can anyone share any similar experiences and outcomes?
But most likely it wouldnt be considered a total loss by the insurance company. Ive heard of frames getting replaced before.
ya, your frame might get replaced. i read a thread a while back that this happened to a guy and he said his truck has been great and had no problems since the repairs. thats gonna be alot of money to repair tho so it might be totalled depending on other damage
They have a machine that will pull on your frame (You anchor down the car and work your way around to all the troubled spots). I think being totaled will depend on other damage (According to your description) Make sure to check your engine and drivetrain thoroughly. even for problems that might occur. When it's all said and done, if you still have that truck, trade it off if possible. Hope you bought GAP (and I dont believe in it.)
Funny - I just hit the "post" button, and my body shop called.
He has a frame machine, and is confident that he can straighten it to within specs. He also said that he will know more once he starts tearing it down. I'm going there tomorrow and he is going under the truck with me to show me exactly what he is going to do.
At the end of the repair, the truck is going to an alignment guy, whom also I know well and is very good at what he does. He did my alignment at 2000 miles when he put my AS level kit on, and still has all the specs from that alignment. If it doesn't come back with those specs, I guess I won't accept the truck.
Thanks for all your opinions - it really helps hearing them since I have never been in a situation like this.
If you think the frame needs replaced, then take your truck and get a second opinion. Preferably at a dealership bodyshop. As a matter of policy, ford WILL NOT even attemp to repair the frame, they just replace them. They do this on all full frame vehicles (crown vic's, F150's, Superduty's, Econoline's, Explorers, Expy's, Rangers)
That sucks man, hope everything works out for you. I have heard of trucks that new getting replacment frames instead of totalling them, but if push comes to shove, If you don't like what the body shop gives you, don't take it.
Maybe it's just my dealers policy then. They led me to believe it was ford's policy.
i could see a liability issue fixing a bent frame, can't see the damage inside the fully boxed frame.
It's based on money. Most insurance companys total a vehicle when the cost to repair exceeds 75% of the vehicles value. 25k car totals at 18,750 repair cost.
As long as my truck is straight and runs down the road true, I guess it's ok.
I do have confidence in my body guy, and he tells me that "it will be fine".
Maybe for me it's more of an emotional thing - to me the truck will never be the same.
But, on the other hand, I've just babied this truck since I bought it new 6 months ago - now to me it will be more of a "beater" - run it hard and plow those deer.........
