Problem
Old Feb 5, 2009 | 06:00 PM
jalichoacan's Avatar
Problem
ok.. so i did the Bambi Vision (how to jumper your fog lights so they stay on with your high beams) and it doesnt work when i pull the high beam lever nothing happens, when i push it to click my headlights turn off
i followed these directions: http://www.landstromsfoundry.com/Tec...Foglights.html
does anybody know what my problem is?
Old Feb 5, 2009 | 06:05 PM
05RedFX4's Avatar
Linky no worky
Old Feb 5, 2009 | 06:06 PM
ATOM's Avatar
that link don't work. i did it with my truck and it worked fine.
Old Feb 5, 2009 | 06:08 PM
I've already got this so called, "Bambi Vision"... because I installed my own aftermarket fog lights. I plan on installing another set, so this way, if someone thinks they are blinding me with their little highbeams on with their car, I will be like the sun in their face.
They better bring the shades and suntan lotion too...
Old Feb 5, 2009 | 06:10 PM
Fixed linky
Old Feb 5, 2009 | 06:38 PM
oh and my fuse only has 4 pins.. its missing the middle one next to the one thats bent. is that an issue??
Old Feb 5, 2009 | 06:44 PM
HKnFORD's Avatar
Excellent idea That way, a vehicle doing 70 mph will be heading in your direction...and not be able to see?
Old Feb 5, 2009 | 06:53 PM
05RedFX4's Avatar
I would think the missing pin is your problem. There should be 5 pins on that relay. My guess is that your fogs don't work at all anymore. Does your low beams work, how about the high beams?
Old Feb 5, 2009 | 06:55 PM
Originally Posted by 05RedFX4
I would think the missing pin is your problem. There should be 4 pins on that relay. My guess is that your fogs don't work at all anymore. Does your low beams work, how about the high beams?
there is 4 pins. my fogs work aswell as my high and low beams.. but not when i did this bambi.. the picture on the link shows 5 pins no?
Old Feb 5, 2009 | 06:57 PM
05RedFX4's Avatar
What works now and what doesn't?
Old Feb 5, 2009 | 07:01 PM
when i pull the high beam lever nothing happen (my regular lights and fogs) but when i push it to click my headlights turn off and just the fogs stay on.. if i just got 4 pins and i fold the left one, would it work??
Old Feb 5, 2009 | 07:02 PM
But I'll be able to avoid them, because they can have a 5% tint on the windshield, suntan lotion on, and sunglasses, but they will still get severe sunburn, and will form cataracts in their eyes, plus get a lethal dose of x-ray and gamma rays, and I will still be able to see them.
Old Feb 5, 2009 | 07:04 PM
lol dude
you got some imagination
Old Feb 5, 2009 | 07:05 PM
05RedFX4's Avatar
Ok, so you have low beams and your fogs work and when you click the switch for high beams the headlights don't work but the fogs still do.
Is this correct?
Old Feb 5, 2009 | 07:09 PM
Is this correct?
yepp.. when i pull the switch towards me.. but when i click it forward the low beams turn off. its a bit confusing and im running outta words, but you get the idea
