Keyless Entry Added-HELP!!
Old Feb 3, 2009 | 11:07 AM
Originally Posted by 05supercrew
I have the stick on key pad and it doesnt work with my aftermarket alarm. It will open the door but the alarm sounds as soon as I hit one of the buttons.
I have the stick on as well. The dealer salesman helped me program the the stick on and the alarm system to match my key fobs. Then he kept the factory code. All I have is what I programmed in.
What started all this is trying to eliminate the stick on and go to the keypad handle. I found out that the stick on actually is just a frequency signal just like the key fob. You just hit the 5 didgit code rather than one button.
Old Feb 3, 2009 | 03:38 PM
05supercrew's Avatar
Yup that is what I was told, since I dont use it I wasnt concern with getting the door handle key pad. I curious to seee if the bsm solves your problem. I think it will.
Old Feb 3, 2009 | 03:46 PM
Is it BSM or BCM?
I just spoke with the guy at the dealer that has been helping me. He talked to the tech that does this stuff and the tech advised that I needed the keyless module that is in the BCM, and that there may or may not be some wiring needed to hook it up. He is going to get an estimate of what it will cost me.
Old Feb 3, 2009 | 04:02 PM
Is it BSM or BCM?
Im not sure I took mine out of the car and bought it to the bone yard and they just gave me another one.
Old Feb 3, 2009 | 06:17 PM
Man that sounds like a complete PITA!
Old Feb 3, 2009 | 09:54 PM
That pretty well describes it. The things i get into, and I'm hard headed once I start.
Old Mar 14, 2009 | 12:59 PM
Ok, it's been awhile, but I had to find a Saturday when the electrical guy at dealer would be working and I was free. Took the truck in first thing this moring for him to start tracing everything out and for him to determine if I had the Security Module inside the Body Control Module. Everything indicated I did, yet it would not retrieve a factory code. When he got into the box, the Security Module was there. He started diagnosing and found that there was a ground wire missing. They probably did not install it since i did not originally have the Keypad. Once he grounded it, he was able to program it and retrieve the code. Took about 2 1/2 hours and the charged me $125. So now I have a functioning Keypad Handle and I get to remove the stick on pad. It would have been "plug and play" had the ground wire been there.
Old Mar 14, 2009 | 01:11 PM
Screw-Me-05's Avatar
Sweet, Glad it all worked out for ya but for a buck and a quater..... OUCH
Old Mar 14, 2009 | 01:20 PM
MAD IN NC's Avatar
Congrats! if you are like me - you have to finish the project! Sounds like the right tech finally stepped up....
Old Mar 14, 2009 | 01:31 PM
The service manager originally tried to program it for me free, and it would not. He spent almost an hour on it himself. Then today, the tech spent a couple of hours on it. If I had to order the security Module, that would have been $172 for the part. So, I'm happy to get out for the $125. It's worth it to me to have the factory Keyless handle. The stick on has worked well, but it's 4 years old and the keys are discolored a little and the battery is getting weak.
Old Sep 23, 2009 | 12:06 PM
bubba stx's Avatar
Unhappy 09 f150 stx
I am haveing major issues ! My truck came with a access code in the glovebox but no keypad on the door.. So i installed a oem keypad but it doesnt work nor do the keys lite up when pressed ? Dealership said there computer didnt find the unit ? Does anyone have an idea
Old Sep 23, 2009 | 01:25 PM
05RedFX4's Avatar
Does your truck have factory keyless entry and power locks? You need both for it to work. 04-08 stx's did not have either.
Old Sep 24, 2009 | 03:47 AM
code58's Avatar
He has indicated in other posts that he has factory locks and KE (keyfobs) I believe they actually started offering that stuff on the STX plus a bunch of other stuff in about '06, which they didn't offer originally.
Old Dec 4, 2009 | 04:27 PM
Maverick 15's Avatar
Anyone have a part # on the BCM that was able to successfully work a recently installed LT handle with keypad keyless entry on a XLT that didnt have keyless entry previously ?
Old Dec 4, 2009 | 04:30 PM
I have an early 2005 XLT that had to be programmed at the dealer, but I am sorry, I do not know my part number for the Body Control Module.
