Aftermarket Headlights??
I think he means - he purchased some aftermarket 'light bulbs' and wants to know how to remove the headlights to install the new bulbs.
- remove plastic screw and flap cover to the inside of the headlamp
- remove the (3) 10mm screws and yank hard
- twist out the light bulb and replace
I believe you have to take the whole assembly out to replace the bulb, but it is only 3 bolts on each lamp and you have to move the liner also but it can just be unhooked with the tab screws and then simply moved over
