AAL installed. Couple questions.
Old Jan 11, 2009 | 08:20 PM
Djacobs28056's Avatar
So I thought I'd post pics, sorry the quality sucks. First one is before, second one is after. And I took off the pin stripes Saturday. Also, I noticed my shock bracket on the axle was contorted. Anyone ever fab up some new ones? Anything I should consider when fixing this. Also, it seems like the shocks are close to bottoming out, how can I test the travel on my rear shocks?
Total lift measuring from center of wheel well... 3-1/2.
Old Jan 11, 2009 | 08:24 PM
The shocks may be bottoming out, which may have caused the mounts to get bent up. Only way I can think of is taking off the shock and measuring then take the measurements and estimate how much travel your suspension has.
Old Jan 11, 2009 | 09:28 PM
I noticed the bracket bent before the AAL install. I need to fix it. Just making sure its straight forward or if I should beef up from OEM with thicker steel. I also believe shocks are bottoming out due to AAL. Just seeing if anyone else has had this happen.
Old Jan 11, 2009 | 09:51 PM
When I had an AAL on I believe my shocks would bottom out going over speed bumps.
Old Jan 11, 2009 | 11:22 PM
dkgreyf150's Avatar
what brand is the add a leaf???
Old Jan 12, 2009 | 02:22 AM
Tylus's Avatar
how do your shocks bottom out due to a AAL?
they are getting stretched out...not compressed...even going over a speed bump, I don't get it????
Old Jan 12, 2009 | 07:37 AM
Cooper443irty's Avatar
They bottom out on the extension stroke, over extended.
Old Jan 12, 2009 | 11:08 AM
bjp207's Avatar
that is a huuuuge tool box, I want the smaller weatherguard like that
Old Jan 12, 2009 | 11:10 AM
Tylus's Avatar
gotcha...could you say they "pulled out"
Old Jan 12, 2009 | 01:09 PM
Correct.
Old Jan 12, 2009 | 01:37 PM
last5oh_302's Avatar
Or, "topped out".
"Bottomed out" threw me off as well.
1st4x4; now your tires look small.
Old Jan 12, 2009 | 01:54 PM
Considering what an AAL does to shock extension it makes perfect sense.
Old Jan 12, 2009 | 06:45 PM
Tylus's Avatar
agree...it was just the choice of words that threw me off
Old Jan 12, 2009 | 07:55 PM
Yeah, Yeah I know the tires look small. I got 3-1/2" b/c I measured after leveling kit and it had dropped the back some so yeah about 2" of lift over OEM. I am bottoming out due to bent bracket. I can either replace shocks or pour kerosene over the speed bumps. So I stopped by 4 wps today and ordered some pro comp shocks 2" longer then OEM. Should get them either tomarrow or WED. YES I HAVE A MASSIVE TOOLBOX. But it looks SO good on the truck IMO since I have to have it on there for my job (It's not chrome). Ive got a bunch of tools, a fire extinguisher, emergency response equipment, and I still have room in there! it's 27" wide and the company paid for it, not me. Now, I'm lookin for some 35"s. KM2s would be LOVELY. Any opinions on the now missing pin stripes?
Old Jan 12, 2009 | 07:56 PM
BTW, I ordered the kit from FAT BOBS GARAGE in utah
