Leveling / Tire Question
Old Jan 8, 2009 | 01:18 PM
Deluxf150's Avatar
Here's a little background,
I have alway been a lifted type guy, but with my '05 I thought id try something different. I dropped it 2/5, w/ 20's.
Now im tired of it lowered and driving so cautiously to not hurt anything (I know a 2/5 isn't slammed, but I drive it like its lifted)
I'm lookin for a fix to hold me over for a long while till I have the coin to do a full 6" on 35's. I'm looking to run a leveling kit (actually level w/ rear) on 33's, id also like to keep my wheels is possible. Just easier to buy tires only.
What would my options be and can I see some pics?
Oh and im lookin for the 2wd guys
Thanx for all the help guys!!
Old Jan 8, 2009 | 03:40 PM
anaheim_drew's Avatar
Here is a local buyer for your lowering kit.
https://www.f150online.com/forums/st...uch-lower.html
Old Jan 8, 2009 | 04:08 PM
Jpaye's Avatar
But you did not answer his question
Old Jan 8, 2009 | 04:19 PM
But I did give a solution that will help him reach his goal
Deluxf150's Avatar
Hey guys. Do I know you from somewhere??
Another reason for the lift, is that im also in the market to drop about 15K on a toy hauler and a couple quads. Towing would be a pain as it sits now. I could bag the rear to compensate for the weight, but then i run the issue of clearance on the dirt for trips to the desert
EDIT: Thanx drew. Ill go check it out. If i do lift it, im hoping the cost of the new tired and lift will be mostly covered by the sell of the drop
Old Jan 8, 2009 | 04:24 PM
Jpaye's Avatar
You sure do, I think if I were you, just go back to stock and buy a leveling kit for the front, then you can 33's
Old Jan 8, 2009 | 04:31 PM
Deluxf150's Avatar
Thats what im thinkin, but im lookin for some pics of that set up on a 2wd to see if i like it or not. Maybe my tax return will be big
Old Jan 8, 2009 | 04:36 PM
do bilstein 5100 before you buy a spacer. much better ride. especially since you would be totally killing your shocks since you would be going from -2" to +2" on the shocks. They usually will tolerate a ride height change once, but not twice.....
Old Jan 8, 2009 | 04:42 PM
Deluxf150's Avatar
I'm not concerned with the shocks, I have 45k on the truck anyhow, its about to replace them.
Old Jan 8, 2009 | 08:36 PM
Tylus's Avatar
x2 with Patman. get the Bilsteins then. Normally I vote no for them vs. a leveling kit, but if the stockers are worn, why not upgrade 'em?
Old Jan 8, 2009 | 08:57 PM
Deluxf150's Avatar
Will they provide any lift?
Old Jan 8, 2009 | 09:11 PM
Tylus's Avatar
yes. they go from 0", 1", 2" of lift. so set them at the 2" point and that will put your front end about 1" taller than a stock 4x4 (using OEM 4x2 components)
then your requested 33" tires will fit just fine...and you shouldn't need anything out back as long as you re-use all your OEM stuff there as well
Old Jan 8, 2009 | 11:15 PM
yea bilstein 5100 will give you up to 2" of lift in the front, and will handle and ride much better then your tired old stockers
Old Jan 8, 2009 | 11:29 PM
Deluxf150's Avatar
Cool. Ill look into them.
Old Jan 9, 2009 | 12:29 AM
DOD 4.6's Avatar
hey delux, im about 45 minutes away. im way interested in your lowering components. shoot me an email at sgdini@csupomona.edu
