Factory oil filter, anybody have probles getting it off?
Old Dec 23, 2008 | 09:30 PM
justjack's Avatar
just stabbed screw drivers through it and unscrewed it that way, and got it out. Not sure about just Motorcraft filters but oil filter changing must be tricky for these tricks.
Same here. works like a charm
I changed the oil on my truck the first time and it wasn't too bad. My parents bought a new Jeep Compass with this little dinky oil filter... that thing was like superglued on! Granted I just drilled a hole in it and used the screwdriver trick... but it was a pita nonetheless.
Old Dec 23, 2008 | 09:33 PM
DARK KNIGHT08's Avatar
Changing the oil for the first time was a PITA. The filter was on so tight I had to take it down to the dealer just to get it loose.
Old Dec 23, 2008 | 10:41 PM
ZEEKA's Avatar
I let the dealer do the first one because of the gorilla that screws on the filter at the factory. Since then I can unscrew it with my hand only, no tool needed.
Old Dec 24, 2008 | 06:57 AM
openclasspro#11's Avatar
try a large pair of channel locks
Old Dec 24, 2008 | 11:12 AM
pldjr0187's Avatar
Tasca Ford changes my oil..... I don't think they had a problem
Old Jan 4, 2009 | 04:31 PM
Moltenice's Avatar
Mine was on there fairly snug.. Not to mention it's location makes it super easy to work with.
But after that OEM filter came off I threw a K&N on there and have used them with Amsoil ever since. Much easier to deal with.
Old Jan 4, 2009 | 05:59 PM
Turbo77's Avatar
Oil filter? Where's the oil filter?!
Oh wait... I get my oil changes/tire rotations/owners manual recommended services for... wait for it... here it comes... F-R-E-E...
I've heard they're a real biotch though.
Old Jan 4, 2009 | 09:49 PM
Moltenice's Avatar
I wouldn't let the dealer change my oil if they PAID me..
When my mother in law found out how much my oil was, she said I should go to Walmart where they change it for less then $35 and have my truck vacuumed
Old Jan 4, 2009 | 10:01 PM
Turbo77's Avatar
I've watched (without them knowing) the mechs work on my truck, and I can honestly say they baby it just as much if not more than I do. They even let the rpm's even out b4 putting her in gear.
No need for them to vac it out, cause I don't let the int. get all crappy.
High caliber of employees @ Wallyworld though. They offer the "Bill Me Later" option for oil changes too?
Old Jan 4, 2009 | 10:06 PM
Moltenice's Avatar
Probably....
I had bad experiences with dealers.. The kids driving it back to the bay only a few hundred feet away and revving it like I cant hear it.... I've found things missing after the fact, and have had them forget to tighten the drain plug leaving a trail of oil out to where they gave me the key with a mechanic running out and following the trail
Plus I prefer a higher caliber oil.
Old Jan 4, 2009 | 10:16 PM
Fifty150's Avatar
OEM 25400 Oil Filter A Cap Wrench 74/76mm
This 'A' Cap Wrench has a 74-76mm diameter and 15 flutes. These specially designed end cap wrenches remove hard to reach multi flute oil filters. Use with 3/8-inch drive tools. This wrench will not damage or crush filter. Heat-treated for strength and durability.
Old Jan 4, 2009 | 10:18 PM
Fifty150's Avatar
Originally Posted by shorse
besides oil and filter, tire rotate, is there any other maintenance needed? like grease zerks?
Check your Maintenance Schedule @ GenuineService.com
Old Jan 4, 2009 | 11:00 PM
Probably....
I hear ya... when I had my '03 Escape, I let a Ford dealer change my oil and filter for $9.95 (back in the day when this stuff was still cheap!) with a coupon. Well, I fell in for the deal, because it was the same amount or even less than if I did it myself. Well big, big mistake... they overfilled it with oil by 1 quart and left the oil cap off. Drove it home and noticed this funky smell of burning oil. I figured they spilled a little on the exhaust when they were changing it. I got home, and it was retched! Not only did it coat everything in my engine compartment with oil, but it was smoking like crazy! They totally forgot the oil cap! I called them up, and they told me to drive it back down... with nothing in the oil cap. So, I sarcastically asked them if I should put something in the filler so it would spray... they said, "No, just drive it!" I was like... WTF!? So I got a shop rag, using common sense, and wedged it in there and it worked. So I got it to the shop, and I go in, and they hand me my oil filler cap, and they said, "Sorry, just screw it on." So I questioned them about the mess and they told me to take it to a car-wash and spray it off. I then yelled at them and said, "You people obviously don't care about what you did to me. I want you to go out, put this oil cap back on, and I want this engine compartment spotless you little jerks!" They were like, "Yes, sir!"
From then on in, I've always changed my own oil.
When I had my head gaskets done on my '07, I still changed the oil and filter, even though the oil was less than 500 miles old.
At least they did change the filter when they changed the oil.
But... I don't take any chances.
Old Jan 4, 2009 | 11:07 PM
Moltenice's Avatar
Thats horrible.
