How to adjust door tightness on a supercab
pdf
The catch pins are not adjustable, all door adjustments are at the hinges. If you PM me, I can email you a pdf with instructions for adjusting the rear doors, the fronts are similar. When my front door wasn't closing tight enough, it was actually the rears that were loose, you could see the bottom of the rear door bounce a bit when you closed the front.
