04 5.4L cam failure
04 5.4L cam failure
Hey, guys I just found this site. Father inlaw has 5.4L 3 valve lost a roller on rear intake valve cyl #2. Hope this is not common, due to the fact I have a 2000 model 5.4L. Well went to help him today and the book says to depess the valves and remove rocker/rollers at certain crank position before removing camshaft. Is this the only way, cause the tool to do this with is $200.00. Any help would be appreciated. Thanks Chris
Its all pretty straight forward and only a few hand tools are needed. A low torque wrench is also requried. One other tip, clean all the dirt from the top of the valve cover because it likes to fall in the engine.
Do a search for some of my posts. I got a lot of good help advice and I added the info that I had.
I found the valve spring compression tool on ebay for $60. It was used and in very good condition. Its tricky to find. I couldnt find the wedge tool.
BTW the 04 and 01 have different valvetrain.
I bought the valve spring compressor and timing chain wedge from http://www.fordspecialtools.com. Here's what I paid...
PN 303-1175 Locking Tool, Timing Chain $90.38 ea
PN 303-1039 Compressor, Valve Spring $147.73 ea
Go to tasca ford for parts (http://www.tascafordparts.com)
the camshaft caps do require a low torque that you'll need a in-lb torque wrench that goes below 100 in-lb.
Also, the camshaft phasers have a one-time use torque-to-yield bolt. You'll need to buy a new one to re-install the phasers (a few bucks from the dealer or tasca).
