Help on rims and tires
Hey i need some help on what would look better I am looking at Incubus Poltergiest rims 20x9 6.19 backspace 30mm offset what would be the absolute biggest tires I can put on them I have a stock 2005 F150 ext cab 4x4, Or if i went with the same wheel in a 17 in what size tires could i use, anyone have pics? thanks for the help
You could get a 305/50/20 they should fit without a problem, most of the tires this size are street tires. The next step would be a 305/55/20 they might fit, the reason that I say might is because they are around 33.5" tall. If they do fit I think that you will have to do some trimming.
As for 17's a 275/70/17 (32")and 285/70/17's (a little less then 33") will both fit. I don't know if anything larger will.
