What is up with the transmissions on these trucks?
Old Nov 28, 2008 | 02:50 PM
TJ05FX4's Avatar
Ok on to my next stupid question
How exactly do I reset the PCM? Just disconnect the battery? Or is there a process I have to follow to do it?
Thanks for the tips. I'll be getting a tuner in the next couple weeks, but I can use all the help I can get in the mean time.
Old Nov 28, 2008 | 05:59 PM
Ftruck05's Avatar
Disconnect the battery for atleast 30 minutes, This will reset the computer and your truck will feel a lot different for about 500 miles.
Old Nov 28, 2008 | 06:34 PM
Disconnecting the battery for 30 mins, then turning the igniton to try to start it with the battery disconnected will ensure the capacitors drain and all the power gets fully drained out of the whole truck.
I trick I learned a while back dealing with an Escape that had auto tranny shift problems.
Old Nov 28, 2008 | 06:52 PM
northazoffroad's Avatar
just wondering what you meant by it will drive different for 500miles drive better or worse i drove the **** out of mine from day one and it feels like it has more power than any other stock 5.4 i drive alot being that i work at a ford dealership would this be because it has "trained itself" i guess lol
Old Nov 28, 2008 | 07:27 PM
talked to senior mast tech said reset computer
Old Nov 28, 2008 | 10:30 PM
4.6 Punisher's Avatar
Reset it and if it's still not good enough, go with a custom tune.
