Brake Booster Hose Recall?
Does anyone know where the recalled hose is located? I took it in for the recall but I don't see anything new under the hood
Here ya go
NHTSA Campaign No: 08V208000
Manufacturer's Campaign No: 08S05
Manufactured From: 04/19/2004 - 05/31/2006
Units Affected: 605,684
Owner Notification Date: 06/27/2008
Description of Defect
FORD IS RECALLING 605,684 MY 2005-2006 F-150 AND LINCOLN MARK LT VEHICLES EQUIPPED WITH 5.4L 3-VALVE ENGINES. THE BRAKE BOOSTER VACUUM SUPPLY HOSE ATTACHED TO THE INTAKE MANIFOLD FITTING MAY SWELL OVER TIME AND LOSE RETENTION FORCE. THIS CONDITION COULD ALLOW THE HOSE TO BECOME DETACHED FROM THE FITTING DURING AN INTAKE MANIFOLD BACKFIRE. SHOULD THE HOSE DETACH FROM THE INTAKE MANIFOLD, SEVERAL BRAKE APPLICATIONS WITH POWER ASSIST WILL BE AVAILABLE BEFORE THE VACUUM RESERVE IS DEPLETED.
Consequence of Defect
ONCE THE BRAKE BOOSTER VACUUM RESERVE IS DEPLETED, THE DRIVER WILL HAVE FOUNDATION BRAKE FUNCTION, BUT WITH INCREASED BRAKE PEDAL EFFORT. REDUCED VEHICLE BRAKING COULD LEAD TO A CRASH.
Corrective Action
DEALERS WILL REPLACE A RUBBER HOSE ON THE BRAKE BOOSTER VACUUM SUPPLY TUBE ASSEMBLY. THE RECALL BEGAN ON JUNE 27, 2008. OWNERS MAY CONTACT FORD AT 1-800-392-3673.
Corrective Action
It's attached to the intake manifold itself, not to the intake tube/air duct/airbox. It's part of the hose assembly that feeds the brake booster.
Thanks! I did not see that hose I will look from the bottom I just wondered where it was.
I never rush them I dropped it off at 10am they called me around 3pm to let me know hat it was ready.
