radiator removal?need some help
Old Nov 22, 2008 | 05:06 PM
azmidget91's Avatar
ok so im trying to remove my radiator to fix some leaks, and i cant get the oil lines out of it whats the trick?
Old Nov 22, 2008 | 09:19 PM
RUSS04's Avatar
I think you will need a tool like the one we all use to change the fuel filter Only bigger
Old Nov 22, 2008 | 09:27 PM
azmidget91's Avatar
figured it out, those are just reallly big fittings on it........but now i think one is stripped zdliu;fhg;aiqg cqbja gr
Old Nov 22, 2008 | 09:43 PM
RUSS04's Avatar
Did you get the fittings off ? And if you did What kind of tool did you use ? I read your post at work i could not reply until i got home I think all of the lines leading to the radiator power steering cooler and transmission cooler need a tool to realese them
Old Nov 23, 2008 | 04:33 AM
azmidget91's Avatar
nope its a line fitting that goes into a piece that floats in the radiator tank, i used a cresent wrench
