Want to see the insides of a cam phaser?
Old Nov 17, 2008 | 07:11 PM
Quintin's Avatar
Sure you do.
These two came out of a 2005 Expedition, and were noisy as hell. Sounded like the valvetrain was about to explode. Let's take one apart.
The back side of the phaser. Pictured off to the right is the trigger wheel for the cam position sensor, and the spring. The pin at 12:00 in the middle of the phaser indexes to a slot on the camshaft.
The trigger wheel is held to the cam phaser by three small roll pins. These roll pins bend or shear off completely. This is where the dull knocking noise comes from.
Old Nov 17, 2008 | 07:14 PM
Quintin's Avatar
Here's the internals of the phaser, shown from the back side with the cover plate removed. The VCT actuator (the thingy sticking up through the valve cover) energizes and allows oil flow into the phaser. The phaser is actually two halves; one half is connected to the camshaft, one half is connected to the timing chain. The chambers, the little spaces between the vanes, create sort of a fluid coupling between the camshaft and the timing chain. Oil flow into one side of the vanes advances the camshaft, and oil flow into the other side retards it.
Old Nov 17, 2008 | 07:41 PM
risupercrewman's Avatar
Very informative, great pics too! Thanks for sharing.....
Old Nov 17, 2008 | 07:54 PM
Silver04f150's Avatar
very interesting, but r there any consequences if you dont get it replaced?
Old Nov 17, 2008 | 07:56 PM
Quintin's Avatar
In an absolute worst case scenario, the cam timing could get stuck somewhere, be it full advance or full retard or anywhere in between. Depending on where it hangs, you'll get various driveability problems, at low speeds, high speeds, or anywhere in between.
It shouldn't fail to the point where engine damage occurs.
Old Nov 17, 2008 | 09:00 PM
homerpete's Avatar
So thats what mine look like lol.
Old Nov 17, 2008 | 09:44 PM
HiVoltage14.4's Avatar
mine proabaly looked like that too. Mine were loud but not anymore. Is there a new part number? Are the new ones good?
Old Nov 17, 2008 | 09:49 PM
next time put a quarter in the picture for size reference. Or maybe a penny if a quarter is too much bling bling fo you :o
Old Nov 17, 2008 | 11:58 PM
Impact9's Avatar
So could you pull the pins out and replace them? Or is it toast once it starts making the noise?
Old Nov 18, 2008 | 12:08 AM
Paralyzer's Avatar
Quintin. have you had to change any on an 06-up yet? supposably they already have the updated phasers in them. im just curiouse cause i have yet to see one that is noisy.
Old Nov 18, 2008 | 02:08 PM
EndlessMoto's Avatar
That's my question too; If the new ones won't do it I want to replace my noisy ones too.
Old Nov 18, 2008 | 02:53 PM
Good thread Quintin! Thanks!
Old Nov 18, 2008 | 08:43 PM
assasinator's Avatar
on my car the exciter fingers are modified to work with my PCM. i broke off all of the fingers but the middle one in the group of three. that is TDC on the passenger side cam cylinder #1.
Old Nov 18, 2008 | 10:06 PM
Pretty interesting. How fun was it to pull that out?
Old Nov 19, 2008 | 07:41 AM
Quintin's Avatar
The latest level cam phaser should be 3R2Z-6A257-DA. I have one of these phasers in my truck, on the passenger's side, and ~40K miles later it's still quiet.
Oh hush.
I suppose if you really wanted to, you could replace the pins, but depending on how badly they're bent, they may have egg-shaped the holes in the trigger wheel (from the wheel kinda flopping around/rocking back and forth). Ford doesn't service the pins separately, and really with all the work you have to go through to get to the trigger wheel/roll pins, you may as well replace the phaser.
2006 and up seems to be good to go. I haven't seen or heard any complaints about engine noise in those related to cam phasers or lash adjusters.
Both sides and the updated lash adjusters, on an '05 Expedition, I started on it first thing that morning and drove it out the building at about 4:00 that afternoon. The Expeditions and Navigators are harder to do, because there's more stuff in the way on the passenger's side (auxillary climate control stuff).
