Fuel addittve????
Fuel addittve????
Anyone use bg products? I was wondering the difference between the 44k and the cf5. cf5 says to us every 4000 or 5000 miles but I didn't see any recommendations for the 44k.
I just use gas with a good detergent, Shell, Chevron, Texaco, Conoco. Have not felt I needed an additive and my plugs came out just fine at 65,000 miles.
first off, ManualF150 is the last person I'd listen to. he and his truck are classic examples of what not to do.
2ndly, the owners manual specifically says not to use additives.
Just use a good brand gas and you'll be fine.
X2 on what the owners manual says. And, stay away from the snake oils that you dump into the crankcase. Use quality oil and change within specification. Clean air, clean fuel and clean oil is what your engine wants and will give you hundreds of thousands of miles service.
One of the top three fuel additives is Techron. Chevron sells gasoline with Techron already added. I'm not sure if that includes all grades, but if it does then if your running Chevron gas, then your running an additive called Techron in your gas.
We don't have Chevron stations in the midwest, and there is a bit of a clogged fuel injector problem here.
Hmm... seems to be some confuzzuzion...
According to the Ford Tech Manual for doing 100k Tune ups states the following:
Change oil and filter
Add BG MOA® Premier Engine Protection)
Lubricate all fittings
Lubricate door hinges, locks & weather strips
Check fluid levels
Cooling system flush, install new antifreeze with anti-seep and anti-gel agents
Transmission tune-up
Add BG Transmission Conditioner
Tune-Up complete, Replace: spark plugs (Platinum plugs extra), air filter, fuel filter and PCV valve
Inspect exhaust system & heat shield (s)
Inspect belts & hoses
Add BG Service Kit 208806
Decarb intake valves
Clean throttle plate
Inspect front and rear brakes
Check condition of wiper blades and washers
Inspect condition of tires and check tire pressure
Rotate tires
So, there you go.
Mind you... BG44k is a PROFESSIONAL product. It is NOT intended for people to be dumping in their vehicle every other tank. Hence the price and why it is only sold by certain, authorized people.
Check fluid levels
Rotate tires
So, there you go.
How often do you use the bg44k and do know what the difference is between that and the cf5?
