Got my spark plugs changed....the results inside.
Old Oct 21, 2008 | 08:55 PM
  #31
JeremyGSU's Avatar
Well, I put my stock intake back on tonight and reprogrammed the truck back to stock. Now I'll see if it comes back on with the stock tune after driving it awhile. If it does I'll take it into the dealer and see if they'll cover it under warranty since my truck is still covered. If it doesn't come on then I'll know it's tune related.
Old Oct 21, 2008 | 09:01 PM
  #32
BHibbs's Avatar
I had mine changed at 110,000 miles and honestly the plugs looked fine. My gas mileage is the exact same with the new plugs as with the old as well...
6/8 broke on mine. The good news is they do have a good process to remove the broken plugs. It just costs ya ...
Old Oct 22, 2008 | 10:26 AM
  #33
CANNONFX4's Avatar
Originally Posted by whitecrystal1
Depends on the dealer. This is something you need to check with them about before you let them do the job. I checked with 4 different dealers, two of them said yes and the other two said any extra work was going to be at my expense. When I called Ford's 800 number to ask about this, they said it was up to the dealer. Then the person I spoke with added that the warranty would only cover a broken plug if it was being replaced due to a warranty claim, like a misfire and the plug broke when they were replacing it. They would not cover it under warranty if I was just having a plug change.
Thanks! That's what I needed to know!
Old Oct 22, 2008 | 06:56 PM
  #34
dbhost's Avatar
AS far as fuel quality, and carbon buildup is concerned, I didn't buy my truck new, and big name brand gas stations are a ways out of my way. I use Shell and Chevron gas whenever I can get it, and I use SeaFoam every 1K miles or so. Should that be enough to keep the plugs clean?
