~~Fast Help Please!!!~~
I have a new problem. Im putting back on the back seat but the bolt on the very right to put in the seat bracing goes all the way through the chassy and the bed. am i supposed to unscrew this like foot long bolt to put the seat bracing on? tell me if you need pictures
That happens to me all the time and it's usually a stick from the trees or ice when the weather turns bad. I have a telescoping "long" scraper I run down behind the cab and it knocks it out most of the time. Something to check first.
it sounds more of a metal to metal squeek from the chassy or something
I also had a left rear spring shackle making noise for a while until I figured it out. Sprayed some penetrating lube in there and the noise disappeared and hasn't come back. That was about a year ago. I would hear it over bumps at low speeds coming into the driveway etc. It took a while for the fluid to work it's way in there but worked and didn't have to tear it apart and lube the bushings. You can duplicate it pushing down on the rear bumper or pulling down on the bed above the wheel well.
