Lift help...4" or 6"??
OK, I'm looking at the Rancho 4" or one of the 6" kits out there. Any suggestions on which one would be best to run 35's? I really want to go with the 6" but not sure how much drive line mods are needed. The 4" kit seems pretty straight forward but no that much more lift over stock. The 6" kits seem to be about the height I want.
I did a 4" kit on a Jeep several years ago and had to get a slip yoke eliminator kit to get rid of drive shaft vibrations and low speed drive line wobble. Do the F150's require any kind of mods to the drive line?
Any pictures of both kits with 35's would be a big help too. The gallery is so non-user friendly anymore.
Thanks guys!
Thanks guys!
heres mine 4" Rancho RS5000's at all 4 corners, nothing but a lift, its sit deal level on pavement, gonna throw an 1.5" shackle lift in the back soon. i love my rancho personally handles better than stock. i got a tad over 5 inches of lift. 35" ProComp Xtreme AT's on 20x10's
Do the 6" lift. I was thinking of going with the 4" lift but very glad i didnt, especially after i parked next to one with the 4 inch the other day.
I have the 6" fabtech and the only drivetrain mod you have to make is with the front driveshaft. You have to grind down the master key, align the slipyokes, and get it rebalanced.
Here's mine:
Here's mine:
Pro Comp 7005 18x9 on 35x12.5 BFG KM2's. Lift is a Pro Comp stage 1 (with Bilsteins 5100 front and 5150 rear) with their skid plate that has saved me a couple times (damn AZ and their rocks), that I'm sure if I had a Fabtech or a Rize I would have messed up that beautiful crossmember and my transfer case may not be functional right now . Overall, I love the lift and does its job perfectly, but I'll be the first to admit that Fabtech, Rize, etc. makes a higher quality product then Pro Comp, although you'd be had pressed to notice (also, you can have Bilstein's front and rear and the pro comp skid plate for about the same price as a basic fabtech kit) and if you can't get there with a Pro Comp a Fabtech or Rize won't get you there either. Just about any lift out there will make you happy, so choose which you like best/can afford
One other thing, I've noticed with a couple 6" kits they have a spacer on top of the factory coil over...do the Bilstien eliminate the use of those by being longer or are they factory length? I know the Dirt Logic do this and are adjustable to boot. If they are stock length what's the advantage of the Bilstien over stock if you DO still use the spacer?
Cool! Yeah, I'm definitely going back with BFG KM2's when I go to 35's. Your truck shows me just how mine will set with 6" lift then. We have the same wheels. The pics of yours when you had the BFG's and stock wheels are one of the factors of my choice to go with the M/T KM2. When did you get the wheels?
Thanks!! I got the wheels when the lift was put on. My lift uses a spacer but I can adjust my Bilsteins 2" to get a total of 8" of lift (which is what I'll be doing when I go up to 37's) along with my 6" spacers. Benefit with the Bilsteins is better ride quality and control, even though you're still using spacers. Rize also uses spacers along with other kits and 99% of everyone on here doesn't use their truck hard enough (jumping them) to have a spacer be a concern off-road, as many other things will fail before that spacer ever will. I will admit a full length shock to get height is a better design but no one (on here) will ever really need it (if you can't get there with a spacer lift, you still won't get there with extended shocks or aftermaket coilovers and anyone who tells you different is blowing smoke up your A**) and it's just not worth the extra amount of money IMHO. Now for bling factor the pro comp, fabtech and of course the king coilovers look great
I don't do major off-roading since it's my daily, I can't afford to tear it up.
I've got my local guy getting prices together for me for Fabtech with and without DL's, BDS and Rize. The Rize I REALLY like but the 8" and 35's I'm not diggin'. Almost all I've seen have 37's and with my 3:55's I think 37's will be a killer on my power. I would like to re-gear but have not found anyone I feel comfortable with yet to tear into it.
I envy your location BTW...My wife and I LOVE the SW. If we could, we'd be there right now! Literally!
I did the install with a friend (his name is MercedesTech on here). Good experience.
Good choice with the KM2s! I love mine. Awesome tires.
The Fabtech replaces the factory shocks with extended performance shocks, so you dont have those ugly spacers ontop of your stock shocks. The ride quality is great with the lift, its just like factory.
Give a call to Josh @ sportstrailerz, i got my basic fabtech for less than most pay for the basic pro-comp
