Have you added foglights?
Old Sep 16, 2008 | 09:13 AM
Capbyrd's Avatar
If so, what are the part numbers that i need?
I added factory fogs to my old civic and all the wiring was already there in the main harness, i just had to add a sub harness on the bumper and one under the dash. Is that the case with the f150? Will i have to run a new harness? All help is appreciated.
Old Sep 16, 2008 | 09:36 AM
jlstang351's Avatar
I just used a pigtail from a factory foglight harness, Will never tell where it came from though. Once you have that its just simple wiring. I wired mine up to a fuse that comes on w/ the key. I have a switch to cut them on or off, but they always stay on!!
Old Sep 17, 2008 | 08:14 AM
ncf150sc's Avatar
I added some when I switched over to the 06 and up front bumper. None of the wiring was there. I ran my own harness and installed a switch to turn them off and on. Not a big deal.....
Old Sep 17, 2008 | 10:17 AM
diggman08's Avatar
can you put a 07-08 bumber(round fogs) on an 04(square fogs)
Old Sep 17, 2008 | 02:05 PM
ELVATO's Avatar
I think that's what ncf150 did.
Old Sep 17, 2008 | 02:11 PM
azmidget91's Avatar
you wouldnt happen to still have the square fogs would you? or any one else who has done the swap?
Old Sep 17, 2008 | 02:15 PM
jlstang351's Avatar
As long as you get the bumper brackets for the newer style 06+
Old Sep 17, 2008 | 02:42 PM
ncf150sc's Avatar
Yes, you can, that is exactly what I've done.
Old Sep 17, 2008 | 03:22 PM
TascaFordParts's Avatar
Former Sponsor
I have lists of all the part numbers you need to add the fogs. Just give me an email address and let me know what you need to replace. ie converting from the square fogs to the round or just adding square etc...
Old Sep 17, 2008 | 04:04 PM
diggman08's Avatar
sent u an email.
thanks
Old Sep 17, 2008 | 05:44 PM
Capbyrd's Avatar
capbyrd@gmail.com
I do not have fogs so i would be adding square fogs to a fogless truck
Old Sep 18, 2008 | 07:28 AM
ncf150sc's Avatar
Sorry, my truck was fogless....
Old Sep 18, 2008 | 09:43 AM
Smok][n's Avatar
heres a wiring diagram i did up a while back that you can use if you dont have the factory harness as i didnt. what i did was tap into the signal wire for the parking lamps behind the headlight switch. that way the fogs come on when you only use the parking lamps and when you have the headlights on. you can use an additional switch like shown in the picture if you want to be able to cut them off when the lights are on. you can find other places and wires to tap into for the signal wire, but thats just how i wanted mine.
this is what i get when i just turn the 1st click n the headlight switch
Old Sep 18, 2008 | 02:48 PM
Capbyrd's Avatar
Thanks everyone. Due to money, I'm having to shelve this for a while.
