guys that added bed extender, got a question
Old Sep 7, 2008 | 11:38 AM
ATOM's Avatar
well my screw didnt have the bed extender and i am picking one up monday. my question is, do i have to have the 4 inserts ? i read one post where a guy had a bedliner and skipped those and just used the 2 bolts. will it rattle or what? i have a linex sprayed liner and i dont wanna cut it up any. any input let me know
Old Sep 7, 2008 | 12:59 PM
lowblueranger's Avatar
I dont know if it will rattle, but I'm sure it wont fit as tight without the inserts. I actually spray bedliners at work, and I always go back after I get done and put the inserts back in. I use a cone dril bit to get it just right so the insert fits. Most to the time you cant tell you had to drill it because the inserts cover the drilled part up. I know the linex liners are a little thinner then the ones I spray(Reflex) so it wont be too hard to get the inserts to fit.
Old Sep 7, 2008 | 01:10 PM
ATOM's Avatar
can someone tell me the widest part of the extender? i have a roll-up tonneau and now im afraid it wont work with a bed extender
Old Sep 7, 2008 | 01:55 PM
greencrew's Avatar
You don't really need the inserts, but they do help. I almost went without them instead of cutting my Bedrug. The inserts give it a better fit when you pin it closed or open. The pins secure the extender firmly in it's extended and closed position.
Either way, it would be real easy for you to try it without the four inserts for a while, and add them later if you have a reason not to like it that way. It's also possible that the sprayed liner will give the pins a snug fit.
The extender is 57 3/4 on the end, but it gets narrower near the top of the bed. I would call it 57 1/4 at the top of the bed where I think you need to clear the tonneau.
Old Sep 7, 2008 | 02:01 PM
greencrew's Avatar
It's a good idea to purchase an extra black post for the extender, that you can bolt on near the end so that it cannot be removed in the closed position. Otherwise they are easy to unclip when the tailgate is locked.
Old Sep 7, 2008 | 03:28 PM
Josiah's Avatar
Honestly these bed extenders are cheap. The pushpin/slides that lock the extender down broke fooling around offroad, popped the little plastic inserts out. Bums me out considering what I spent on it to add it in.
Old Sep 7, 2008 | 03:41 PM
greencrew's Avatar
Fooling around? Dude, I've seen the video of your fooling around! That may be the best pull I've ever seen. It may be the best f150 pull of all time. Did you really expect that little tin extender would stand up to your level of fooling around?
Old Sep 7, 2008 | 04:52 PM
Josiah's Avatar
haha, well thanks! I had a few really loud cheer inducing pulls at pismo I wish I had some evidence of!
To contribute, the 4 holes you need come on every truck, the 2 center holes are what you mount the swivel bolts in, and the top holes are for the slide pins to slide into and lock.
Old Sep 7, 2008 | 05:10 PM
ATOM's Avatar
thanks alot for the measure, damn thing wont fit. oh well, well if the things breaks offroading, regardless of who has it, then i guess i'll keep my 2x10 and call it good.
Old Sep 7, 2008 | 06:18 PM
greencrew's Avatar
I learned a few things just watching you pull, and now I understand why you were so confident you could pull him out after the others did nothing more than bury him deeper. I really should make some comments in that thread. I'm wondering what you said to him after you hooked up those straps.
Old Sep 7, 2008 | 09:55 PM
04F150supercrew's Avatar
speaking of bed extenders i just got a used ford bed extender, but i have no mounts for the box sides, only the extender- anybody know how i can get these???
Old Sep 7, 2008 | 10:15 PM
greencrew's Avatar
Ford parts department has them. I had the part number for the 97-03s, but I'm not sure if they are the same 04+. I don't know about ordering the four plastic inserts?
Old Sep 7, 2008 | 10:18 PM
i went to the local ford dealership and they told me that the hardware was only available with the bed extender and not sold separately
Old Sep 7, 2008 | 11:04 PM
greencrew's Avatar
Maybe they stopped selling them to thwart the business of stealing extenders and selling them on eBay. :o It was a big business when they first came out. I bought the hardware myself for an 01 back in 04. The part number is posted here somewhere.
Old Sep 7, 2008 | 11:23 PM
greencrew's Avatar
These are the part numbers I purchased from Ford back in 2003 for a 2001 truck. The mounts for the box sides were W707381 S900. They look the same to me, and screw in real nice if you use a 3/8-16 tap lightly first. The bracket looked the same also. The dealership included my extender with the sale, and threw in the brackets after I popped an extender out of a truck on their showroom floor without opening the tail gate, so I didn't order anything this time.
SPO W707381 S900 SC&WSHR M10X30 TOR S
SPO 1L5Z 99286B23 BA SUPT CORN TUB P/U BO
