Ignition problems/stuck key
Old Sep 4, 2008 | 02:14 AM
Josh M's Avatar
Exclamation Ignition problems/stuck key
Hey guys, first problem I've had with the 07' Today I wne to pull the key out and it wouldn't come out. I made sure it was in park and tried again with no luck. After pulling on it and shaking it a bit it finally popped out. Then I put the key back in and tried to start the truck and the key wouldn't turn. I shook it around a little and it started, but then I shut it down and pulled the key out and the chimming stayed on like the key was still in the ignition. I tried the key again and it worked, just feels sticky. Should I try a little WD-40 or pull off the gryphon and take it to the stealership?
Old Sep 4, 2008 | 02:18 AM
Dealership time.
Old Sep 4, 2008 | 02:27 AM
Tylus's Avatar
+2 on Dealership
don't mess with that stuff
Old Sep 4, 2008 | 02:52 AM
GreenBuck50's Avatar
+3... I'd be afraid to mess something else up and they blame it on me and not pay to fix it.
Old Sep 4, 2008 | 06:37 AM
NVERL8's Avatar
Try unhooking your battery and then see if the key turns freely. This same thing happened to my fusion and it turned out it was a trim piece that stuck inside the shift handle that got hung up on the "must be in park for the key to come out" safety switch. There was a TSB from ford about it (for the fusion) but it was $175 fix and my car is way out of warranty, I took the piece off and did a little trimming and have not had an issue since.
