Install Audiophile SUB in another make vehicle
Old Aug 19, 2008 | 10:16 AM
2005lariatky's Avatar
Can this be done. I'm selling the truck and thought about taking out the sub and putting it in my wife's car. I guess I will need a amp to drive the sub. Shed some light!
Old Aug 19, 2008 | 12:09 PM
ford2004F150's Avatar
The amp is mounted on the box...
All you need is to LOC or head unit that pushes low levels.
Run a remote turn on wire and you are good to go....
Yes, It can be done.
Old Aug 20, 2008 | 09:00 AM
What is a LOC?
Old Aug 20, 2008 | 09:13 AM
JesseRohr's Avatar
Line Out Converter
Old Aug 20, 2008 | 01:20 PM
928gt's Avatar
Yep, just installed one behind the seats in my 2005 F-350 Crew Cab. It was easy in my case since I was installing a Factory Ford Navigation/Audiophile head unit that had the connector for the sub.
In addition to the wires mentioned, you also need a 12 volt power supply, Ford originally used a 25 amp fused power supply.
Old Aug 20, 2008 | 07:57 PM
What sort of power supply did you use?
Old Aug 22, 2008 | 04:58 PM
LosBanosF150's Avatar
what's the actual size of the subwoofer speaker anyway?
Old Aug 23, 2008 | 09:35 AM
SteveVFX4's Avatar
umm, that would be the truck's main battery. I'm sure from the factory the audiophile system is combined with the main wiring harness/circuits. But if you're hooking up the amp on your own, the best practice is to run the power wire directly to the battery and have an in-line fuse to protect it.
LosBanos, it's 8 inches.
