New Self Made Exhaust Installed
Old Aug 1, 2008 | 01:01 AM
Originally Posted by RoushF150
A 6" angle grinder would burn a hole right through the pipe.
Only if you don't know what you're doing.
Old Aug 1, 2008 | 01:39 AM
styxnpicks's Avatar
Lol!!!!
Old Aug 1, 2008 | 01:41 AM
ThumperMX113's Avatar
Wow, this guy knows his stuff !!
Old Aug 1, 2008 | 04:19 AM
azmidget91's Avatar
Better to be there all day fixing a bad weld than spending 5 minutes chewing through $5 worth of cheap exhaust tubing.
Old Aug 1, 2008 | 07:48 AM
long07's Avatar
Killbee I see you are running the super swamper A/Ts! what do you think of them? I have seen they are going to come out with a 295/70/17 and thought this could be good insted of the Nittos that I am running now!
Old Aug 1, 2008 | 10:08 AM
killbee's Avatar
I like them alot, they ride really well for this big of a tire,hardly any noise at all. The only thing bad so far was geting them balanced, it took alot of weight on a couple of them to balance. Not an issue just more than normal, maybe its the size of the tire.
Old Aug 1, 2008 | 10:39 AM
RoushF150's Avatar
True. Grinding is kinda like welding.
Old Aug 1, 2008 | 10:51 AM
midnight08's Avatar
grinding is not like welding...
Old Aug 1, 2008 | 11:23 AM
RoushF150's Avatar
You didn't get the connection.
Old Aug 1, 2008 | 02:40 PM
azmidget91's Avatar
umm then can you explain how grinding is like welding? or is this an inside joke that no one but you understands?
Old Aug 2, 2008 | 12:26 AM
RoushF150's Avatar
If he grinds like he welds, the outcome is the same.
Old Aug 2, 2008 | 01:07 AM
Well at least if he grinds a hole in the exhaust he knows how to weld the hole he made closed.
Honestly it's easier to blow out a hole in the tubing with a welder than it is to grind a hole through it, especially if you don't know how to set up the welder properly. Grinding is just trigger and pressure.
Old Aug 2, 2008 | 01:10 AM
RoushF150's Avatar
Well at least if he grinds a hole in the echaust he knows how to weld the hole he made closed.
It's a vicious cycle, one that will end up in a 6" diameter bird poop bead.
