what do i need for my 2wd front end to sit like 4x4
ive herd different things from springs to shocks but what excatly do i need for the front of my 05 supercrew i have stock rear blocks on the way already im just trying to figure out the front
Or I think it was fabtech I saw makes springs and struts for your truck...
The Fabtech route will cost a bit more tho. Only looking at about 80 for the spacers.
I just ordered some 2.5 inch spacers and a 3 inch block for my 4x4 today!!
Great company to deal with!!
Here's the link: http://www.autospringcorp.com/
Side note: FYI... I'd stick with Autospring kits if you go for a leveling kit because they build there's with an offset so that you will have minimal wear to your ball joints other companys dont....
All you need is a leveling kit up front and like you said, the rear blocks. You can get a 2 inch or a 2.5 inch spacer. Every truck is different so I would suggest measuring the front of your truck and get stock numbers from a 4x4. That will let you know if you need the 2 or the 2.5 .
he needs more than just a leveling kit up front. if he wasn't putting the rear 4x4 blocks in, the leveling kit would be enough.
to truly sit like a 4x4, get the 4x4 front coils, the 4x4 rear blocks...then get a leveling kit if you want to sit high and level
thank you! I was told I need 4x4 coils then someone told me the coils are all the same and that all I need are shocks b/c the perch's are different. Im just trying to figure out what to do I already have front 2.5"
The size difference between a 4x2 and a 4x4 is about two inches. If he adds the front coils and the leveling kit that would add about 4 inchs of lift. That would put severe stress on the ball joints. He could add the coils by them self or just add the levleing kit.
I think the 4x4s have a different setup up front. What it is, im not sure. I wish I could be of more help. Maybe one the senior gurus will drop in. But from reading everything here. That is what has been said here. You can prob. do it but it will be very bad for your front suspension. Just trying to help out shocker.
4x4 and 4x2 share the same components. 4x4 gets the taller coil assembly and half-shafts, but otherwise identical. the 4x4 coil is 1-2" taller.
basically, a 4x4 coil will make the truck sit roughly dead level. then the rear 4x4 blocks will make it sit like a OEM 4x4. if he wants more space, he can then install a coil spring spacer (leveling kit).
without the spacer, a 33" tire should fit with 0 problems. with the spacer, I see no reason a 35" tire won't fit like the 4x4's do
see the pics below
4x4 front end
btw, the quickest, cheapest and easiest way to get some front end lifting is just to install a 2.5" or 3" kit ontop of the OEM 4x2 coils.
only cost you $90 or less and you can still clear 33-34" tires. I think this would be your best bet. and if it's not enough, you can always try another approach and sell the kit to another member here
