Engine Woes
Old Jul 15, 2008 | 02:22 PM
fx4jake31's Avatar
Engine Woes
Alright last thursday my truck started to idle really rough so i took it to autozone and got a diagnostic reading and it pulled the P2106 code so i took it to the dealership, three days later they finally look at it and tell me it's my "aftermarket stuff" which the only thing is a K&N CAI which has the throttle body spacer which relocates the throttle body and they said my throttle body was shot because it was tilted at a 45degree angle from the K&N... sounds like bull **** to me, but i guess i'm gonna order a new throttle body if someone could help me out i'd really appreciate it if you think you know what is wrong.
Old Jul 15, 2008 | 02:48 PM
How can you rotate you throttle body 45 degrees? It only bolts on one way.
I can tell you, that it might be the K&N... it might have fowled up the MAF sensor.
I had this happen on my sucky Ford Escape with a out-of-the-box K&N airfilter... with barely any oil.
Old Jul 15, 2008 | 04:25 PM
curio's Avatar
K&N CAI's for the 5.4L have an adapter which goes between the throttle body and the plenum; thus the throttle body sits at an angle.
OP: The only thing I can think of is that the wires to the throttle body coming from the passenger side of the TB barely reaches it after the K&N install; and it might have caused problems with the connection or cause the actuator to fail. I made sure to give that particular wiring more slack when I saw how tight it was.
edit: everything I've looked up suggests either an actuator failure or a wiring/connection problem. Check this out: http://foxed.ca/rx7manual/2003mazdar...202100W02.html
Old Jul 15, 2008 | 06:01 PM
fx4jake31's Avatar
just got it back from the dealership and to make it run they had to unplug the right side of the throttle body switch so it idles, thankfully i only live a mile from the stealership and i was able to idle home, i guess i'm gonna next day air a new thottle body from ford parts
Old Jul 16, 2008 | 06:18 PM
BestNTx's Avatar
I know when my edge threw the p2106 code, I replaced the TPS and It fixed it. Then it started again, and it turned out to be my transmission.
