hellwig users...question
Old Jun 27, 2008 | 09:01 AM
Allcarfan's Avatar
I received my Hellwig rear sway bar yesterday. Part Number 7663. It came with zero instructions. I have a warranty card and a card with a list of things NOT to do when installing. NO pictures, nothing.
I have not started the install yet, just laid out all of my parts. There are two parts that I have a question about:
The first one is an hourglass shaped bushing. What is that for, where does it go? Do I even need it?
Next, I received two metal sleeves. They are probably an 1-1.5" long with an ID of probably .25". What are these used for, where do they go, do I even need them?
Everything else is pretty standard. I have installed sway bars before, just never seen the two parts I mentioned above.
Old Jun 27, 2008 | 09:35 AM
Allcarfan's Avatar
disregard. I found instructions online.
FOr future references when searching: the hourglass shaped bushings are pivot bushings. The steel sleeve goes through them. There is only one place to put them.
Old Jun 7, 2009 | 09:42 PM
BMS's Avatar
BMS
Registered User
Curious what your impressions are now that you've installed (I assume) and had a chance to drive. How much of an improvement in the handling? I'm considering getting one. Thanks.
Old Jun 8, 2009 | 05:18 AM
svt2205's Avatar
I had one of these on my 07, it was a waste of money. If you plan on upgrading your exhaust, you may find the end links to be in the way. I learned this when I installed my Magnaflow SI/SO.
If you search thru this forum, you'll find very few people talking about adding the bar. That should tell you something.
Old Jun 8, 2009 | 09:59 AM
stompy's Avatar
Well I installed mine this past weekend and I feel like it made a pretty good difference. The install was not bad at all but I have the Roush Off Road Side Exit, so it doesn't come to the back of the truck at all. The truck just feels like it sticks to the road better, I can definitely tell there is a decrease in body roll. I say go for it!
Old Jun 8, 2009 | 10:02 AM
Allcarfan's Avatar
I love mine. I noticed a very big different in body roll upon installing it. Next is a panhard.
Old Jun 8, 2009 | 12:27 PM
Marc Carpenter's Avatar
Mine has been on since the truck had 10,000 miles on it, and it now has 82,000. Makes a world of difference in handling, especially if you like to run the West Virginia Turnpike at 80-90 mph like I do when I make the trip to Mikes T's shop in Virginia.
Heres a tip. If any of your bushings in the kit wear out like mine did on the upper links( new ones are the hour glass shaped , when mine was new 5 years ago the top bushings were two piece and not shaped like these) just give Hellwig a call and they will replace them free. They sent me 8 new bushings and the sleeves for the mounting bolts last week, plus four new bushings for the bottom of the end links. Best $200.00 mod I have made.
Old Jun 8, 2009 | 01:45 PM
4.6 Punisher's Avatar
It sounds like a good mod for lifted trucks, but not so much for stock or lowered trucks.
Old Jun 8, 2009 | 01:51 PM
stompy's Avatar
Mine is lowered with an Eibach Pro Kit and Ground Force shackles and I think it was a great addition.
Old Jun 8, 2009 | 05:51 PM
bjp207's Avatar
what difference does it make?? I rode in stompys lowered truck this weekend and it make a hell of a difference, it really stuck to the road alot better, I would do it to mine but I am concerned with the exhaust clearance
Old Jun 8, 2009 | 06:17 PM
Makina's Avatar
Did you guys do both bars? or just the rear?
Old Jun 8, 2009 | 07:02 PM
stompy's Avatar
I did both bars, Drove it around with just the front bar, didnt feel a whole different. Once the rear bar was on it made a huge difference
Old Jun 8, 2009 | 07:08 PM
Guess I was wrong than.
Old Jun 8, 2009 | 07:19 PM
Windsor's Avatar
My front bar was on back order, so I installed the rear first. I did notice an improvement. I installed the front bar at the same time I installed my Rancho QuikLift struts. That lift sort of changed the dynamics of the suspension, but it corners very well for what it is.
