Check Engine light flashing
Old Feb 10, 2008 | 10:46 PM
Ridinon22's's Avatar
so the other night i'm on my way home from work and I'm cruzing well above the spped limit just threw that in to erk you sticklers out there and my check engiine light started flasing in 1 second intruvals and then shut off and truck road fine no problems other then it being slugish which is no different then it always is. So today on my way to the range and I put it under hard acceleration around a turn and it started flasing again this time it stays on so blah its really annoying Oh and so you know the truck has 37k miles on it so I'm bringing it to ford monday any thoughts on this?
Old Feb 10, 2008 | 11:20 PM
NoLongerJeepin's Avatar
usually if its flashing its the engines way of telling you to pull over. any other cars iv had said something like this in the owners manual
"if the check engine light illuminates the truck should be brought into the dealer within the next ~300 miles. if the check engine light flashes it should be pulled over, shut off, and immedietly towed to the dealer"
try to get the code pulled so you know how serious it is and then go ahead and take it in asap
Old Feb 10, 2008 | 11:21 PM
GJ Screw's Avatar
I am not positive on this and am sure someone will correct me, i think that a flashing CEL usually is tranny issues.. Warranty?
Old Feb 10, 2008 | 11:25 PM
yea it probally is tranny related the tranny has been acting up forever i have brought it to the dealer numerous times for it the warrany just went up but they can get it in under previous problem probably i'm getting a new truck in 5 months anyways so if it needs serious work I'll just get out of it and into a new one but its most likely nothing
Old Feb 11, 2008 | 12:45 AM
A flashing CEL is a misfire.
Old Feb 11, 2008 | 01:24 AM
not so sure your right about this we'll see it stays on now if it is a misfire what needs to be fixed? spark plug?
Old Feb 11, 2008 | 01:30 AM
Read this carefully:
Old Feb 11, 2008 | 07:50 AM
Quintin's Avatar
'05, 5.4 3V, probably a stuck injector or two.
Old Feb 11, 2008 | 09:19 AM
Sackett's Avatar
My truck did the ame thing; however, when in "limp mode" it would run very poor, i.e. limited throttle, sputtering, etc... took it straight to the dealer and stood there while they used the scan tool and it came up misfire in bank 2.
Old Feb 11, 2008 | 09:57 AM
Rockpick's Avatar
Moderator &
Precisely what mine did when two of my injectors failed... it went into that 'flash' mode.
Have you felt it missing (or jerking, for lack of better terms?).
Old Feb 11, 2008 | 10:29 AM
freekyFX4's Avatar
My guess is that you have a failing COP (coil on plug). My daughter's 2003 Explorer has had three of the eight COP's fail in the past six months. Every time one of them fails, the CEL flashes and the car runs a little rough, especially at highway speeds. Check it with an OBDII scanner to see what the code is, but I am betting COP.
Old Feb 11, 2008 | 11:49 AM
05F1FIDDY4x4's Avatar
Mine came on a couple weeks ago. Pulled over and saw that my intake tube going into the MAF was loose. Hooked it back together, disconneted the battery for about 15mins and have not had anymore problems.
Old Feb 11, 2008 | 12:10 PM
When the truck is in limp mode the "Wrench" icon should be lit.
Old Feb 11, 2008 | 05:17 PM
Huitt24's Avatar
My truck had the flashing light also which was a missfire then it went steady after it missfired enough to throw a code. Read the codes and post what they are. I noticed tho if it only flashes it doesnt always throw a code. I have had COP's and plugs cause the blinking light. Good luck
Old Feb 11, 2008 | 09:18 PM
we'll i brought it to my buddy at the dealer he said it was throwing a 301 i think he said and i say was because i got in the truck this morning and the cel was no longer on but i brought it in anyways. he says that code is for misfire in #1 but he said it wasnt misfiring now like i said the truck was driving fine he said the plug might have gotten wet and dried out becasue i do some off roading does this sound right?
