?? For Those with LED 3rd Brake Lights
Does the light now function with the tailights as well?
I installed a revotec 3rd brake light a few days ago, and I noticed that with the ignition or engine on at night with the headlights on, it lights up lightly like the tailights and then gets brighter when I apply the brakes...
Is this normal? I didn't notice before, but does the stock light do this as well?
Just curious if this is normal or not...
Hope that helps!
Good luck!
Same goes for me. Mine works just like the OEM one did.
It's just because the LED's are able to light up dimly with the low voltage that probably runs through the circuit all of the time. The more LED's you have in the brake light, the less likely it will be to light up. The stock light bulbs won't turn on at all with the slight voltage like the LED's will, which is why you don't see the problem with the stock housing.
The RECON may have more LED's than the Revotec, even one or two extra LED's can make the difference in whether the unit will light up or not.
