Drop and Fuel Mileage?
Old May 28, 2008 | 02:55 PM
attworth's Avatar
I wonder if dropping yields better fuel consumption numbers...
Anybody have any input?
This could be my way of getting my truck layin lower.
Old May 28, 2008 | 02:58 PM
crash_lucky13's Avatar
yeah. my fuel mileage went down. kinda did the charger and everything at the same time...
the difference, if any, is going to be small small small
Old May 28, 2008 | 04:30 PM
Dribone's Avatar
yeah, i'd have to say slim to none.
Old May 28, 2008 | 04:33 PM
attworth's Avatar
Dang guys... Thanks...
That's not what I was looking to hear...
Old May 28, 2008 | 04:36 PM
Dribone's Avatar
well you could do what i'm sure a lot of us do and tell yourself it does. at least then you'll feel better about it
Old May 28, 2008 | 04:40 PM
I haven't noticed any difference.
Old May 28, 2008 | 04:42 PM
attworth's Avatar
It's not myself I have to convince....
Old May 28, 2008 | 05:51 PM
listen, bring nascar into it. sounds like your trying to prove it to your wife. draw your truck and show her the aerodynamical difference and it HAS to improve gas. also, it's lower so it's easier for her to get in, more convenient to take out armadillo's (lifted trucks go over them without the pleasant sounding THUD). also, in winter time you can use your truck to push snow!! there's LOTS of good reasons to lower it! get a bedcover like mine and take her out to the middle of nowhere one night...she'll LOVE it.
**this post is CRASH certified**
Old May 28, 2008 | 05:54 PM
attworth's Avatar
Sweet...
Pricing things now.. Just gotta get the ***** to order it and ask forgiveness later...
Old May 28, 2008 | 05:59 PM
Tylus's Avatar
lifting causes MPG drops because you are exposing more surface area to wind...and usually bigger tires
dropping doesn't really cover up any peices of the drivetrain that aren't already covered.
sorry, but no help there.
why not just explain that dropping your truck is cheap, and most cases under $200. 4x4? remove your rear block (1-5/8" tall)
Old May 28, 2008 | 10:08 PM
attworth's Avatar
Definitely not that cheap..
Not 4wd either - I wouldn't be dropping that's for sure..
Old May 28, 2008 | 11:15 PM
Tylus's Avatar
you looking to slam it? or just make the rear-end leveled out?
I had no idea a kit to slam it was in that price range. just leveling it out though isn't bad. there are few slammed trucks floating about that are just amazing looking...and a few 4x4's that have been leveled from the rear that look pretty nice as well
GroundForce_2"_kit_for_<$100
Full_Ground_Force_Lowering_Kit_2"_Front_5"_Rear_fo r_$800
DJM_3/5_Drop...no_shocks_though
Old May 29, 2008 | 12:39 AM
attworth's Avatar
Looking at either 2/4 or 3/5. I made some measurements a while ago, and I'm leaning towards more drop..
I'll probably just do a shackle to start, and buy the other stuff in pieces.
Can't exactly afford everything all at once.
Old May 29, 2008 | 01:48 AM
Tylus's Avatar
understand you 100% on that...luckily a lot of the mods that are available for these trucks can be stacked together.
Old May 29, 2008 | 02:35 AM
Look at eibach. Below is a 2/4 spring kit for less than 5 bills, for example.
http://www.ajusa.com/details/index/2...0Wheel%20Drive
