Rear Axle
Old May 20, 2008 | 03:32 PM
msharris16's Avatar
Rear Axle
Have appointment for a leak in the right rear axle on Friday. 42000 miles no towing (yet) with truck should this be an issue?
Old May 20, 2008 | 03:33 PM
scott1981's Avatar
By the tire or where the axle meets the pumpkin?
Old May 23, 2008 | 01:00 PM
msharris16's Avatar
by the tire
Old May 23, 2008 | 02:38 PM
Tylus's Avatar
it's not common, but it does happen. it's an easy fix though. just expensive if there are more problems
hopefully the axle seal was only leaking outward, so no dirt/crap got into there. if it did, then you might have to replace axle shafts, or the axle
if they quote you more than $500 to fix, I would just go find one in a junkyard and do the swap in your driveway. and if you're 4x2, you can get a 3.73 with LS for <$1k fairly easy...might even get lucky and find a HD axle with 4.10 gears
Old May 23, 2008 | 03:51 PM
ckforker's Avatar
I had the exact problem last week, but mine was still under warranty. I just happened to notice it looked wet on the plate where the brakes are mounted.
Old May 23, 2008 | 04:30 PM
It's a common problem with these trucks. I think there is a thread about replacing the axle seals.
Found it.
https://www.f150online.com/forums/sh...ght=axle+seals
Old May 27, 2008 | 07:51 PM
msharris16's Avatar
update, got truck back today,
"both rear axle seals leaking performed tsb 08-11-1"
"both parking brake levers inside rotors siezed"
caliper assembly on both rears replaced
shoe assembly-parking brake replaced
new cables
all fluids
And thanks for the ESP only $100 for deductible.
Old May 27, 2008 | 08:12 PM
risupercrewman's Avatar
new cables
all fluids
Thats great news for you! Congrads! I have the Ford ESP too! Glad I have it!...........
