leaking grease out of CV boot
I think he meant physical damage to the joint itself, if it just started leaking then your joint is probably fine and you just need a new boot. But if it has been leaking for a while, you may not have any grease left and the joint could be bad inside.
I would at least seal up the hole before driving too much. You want to keep dirt out of there until you get it repaired.
