Adding Tow Hooks to Two Wheel Drive
I did this on a friends truck....
1. take off your lower valence by removing the screws that hold it up in place. (there are also clips on the valance but just gently pull after screws are out and it will pop off)
2. use a drill to make an initial hole in the valence then use a saw etc to complete the cutout...jig saw also works great.
3. Tow Hooks install in the bumper beam into the pre-cut holes and just bolt down
4. re-install the front valence making sure the cutouts fit properly and expand cuts if necessary.
Youll need a screwdriver and a good ratchet set. Time should be around 30 min-1.5 hours depending on your skill level (dont be afraid to break something, you won't)
Cost I would put around 30 bucks for the tow hooks.
I would suggest a Dremel as well...its fairly easy to do. For the amount to cutout just look at your bumper, you will see a distint line of where the cutout is made when done by Ford.
For cutting I would remove the valence and cut from the backside as it is easier to see what needs to be removed...just cut out the "bubble" portion when it is upside down. Cutting from the back will make it look clean in the front which is what you see when you walk up to the truck.
Good luck
Yes, i did the same, some tow hooks are diffrent. I wanna say the 04 and 05 are beefier than the 06 and up. The reason is becouse i did this to pops 05 and my 06 and the two sets were diffrent .They will bolt up either way, but just a fyi. I too was going to cut the valances, but they were cheap enough to buy and justify and make it look stock, becouse trust me, when die hard ford people see a 2wd truck with tow hooks- people come in for a very ,very close look and ask - dam , it came from the factory like that?
