Bouncing Box
Old May 5, 2008 | 09:57 AM
Blue150's Avatar
LMAO!! At the Tundra! Looks like they had to go slow. That Chevy was atleast moving fast. I thought the box was going to come off the Tundra. LOL
Old May 5, 2008 | 05:32 PM
mlawdawg's Avatar
Originally Posted by MOford21
It's just because the frame is like 8x more rigid than the past generation F150... All the force from the bumps has to go somewhere. It's normal.
Can't wait to see how the new ones jump around then, as the frame is suppoed to be even stiffer.
Old May 5, 2008 | 07:57 PM
black'n'chrome's Avatar
I'm glad to see this topic - I thought I had a problem. My truck does the same thing - the back corners of the bed bounce when I'm going fairly slow (~20-30mph) and the road isn't perfectly smooth. I have an '06 SuperCrew w/ 6.5" bed - thought it was maybe worse since I had the longer wheelbase - but sounds like you 5.5 guys have it too.
Old May 7, 2008 | 12:00 AM
Regulator54's Avatar
My 2000 S/cab with 6.5 never caused me a second look. But man, this 2008 S/crew with the 5.5 was sure a surprise the first time I noticed it on some uneven pavement around town. And the drivers side does seem to bounce more than the passenger side, for whatever reason. The middle of the box doesn't move but it looks like the sides and corners are teetering on the centre line of the box. Very different, but apparently normal from the sounds of it. Oh well, at least it's an F150!
Old May 7, 2008 | 01:38 AM
Originally Posted by Regulator54
I'm hearing that it is normal, but what a real weird normal. Looks scary from the inside. Just got to take notice of other trucks to see what they look like. Strange how the Ford shop had never heard of this before, ya, whatever.
Wow, you must be a hoot on Halloween.
Mine moves around, but it hardly looks like something is unbolted.
Like previously stated, your 2000 and your 2008 are on different frames, with the 08 being more rigid, which equals more bed movement, not bounce.
Old May 7, 2008 | 08:35 AM
tomclem's Avatar
Maybe some FYI: IF you have the Conticrap tires, dump them for some good tires. And/or might help to have them check the rims to make sure one or more isn't warped, etc. (had two on mine that way). Also check the emergency break s/u b/c they are known to stick. Way I fix mine is press the brake down slightly then put in reverse and back up. This will free up the brake if it's stuck(usually). My 05' use to jump around all over the place until I fixed these 3 things. I believe just getting a good set of tires makes a world of difference.
Old May 8, 2008 | 12:27 AM
Mark Miller's Avatar
I noticed this on my 2007 XLT 4X4 Supercab with 6.5' bed when i was going 55 mph on a slightly bumpy road.I checked the T-50 bed bolts later on that day and all were tight.
Later Mark.
Old May 8, 2008 | 06:40 AM
JBMX928's Avatar
Graphics Contributor
guys from tundrasolutions right now are probably baiting off this thread and posting like crazy "F150 HAS BED BOUNCE PROBLEM!" " FORD ISSUING BED BOUNCE RECALL" " TUNDRA HAS LESS BED BOUNCE THAN FORD"
blahblahblahblah
Old May 8, 2008 | 01:58 PM
Tylus's Avatar
that is so true ^^^^
we should start a thread about the F-150 tailgate warping to just really mess with their heads
Old May 8, 2008 | 02:14 PM
Irish FX4's Avatar
Are tail gates warp!!
I'm pretty sure i bought a F150 and not a Tundra.
Old May 8, 2008 | 03:56 PM
clayman45's Avatar
Mine was doing the same. There was a TSB and they put a 6x6 metal coil that was supposed to absorb the shock and have less bounce.
It works pretty well.
I have an 05 Screw though.
