Painting Interior Plastic
Old Apr 23, 2008 | 08:07 PM
CANES676400's Avatar
how well do you guys think the paint would hold up if i rattle canned the interior plastic peices
Old Apr 23, 2008 | 10:42 PM
travis08's Avatar
i jus got everything in the middle that was black painted gloss black its gona be work keeping clean i can already tell heres a few snap shots
Old Apr 23, 2008 | 10:57 PM
tardman91's Avatar
If you prep it right and use a good paint (I'd suggest Krylon Fusion [especially formulated for plastics]) it should hold up well for years to come.
Old Apr 23, 2008 | 11:13 PM
doesnt that all have a clear coat on it. i was gonna paint the all the grey plastic black but without a clear.
tardman how would you prep it because its textured plastic and i cant sand it
Old Apr 23, 2008 | 11:18 PM
travis08's Avatar
yeah that has a couple layers of clear coat
Old Apr 24, 2008 | 08:25 PM
no other opinions
Old Apr 24, 2008 | 08:30 PM
ModBargains's Avatar
Originally Posted by CANES676400
no other opinions
Another vote for krylon fusion. Just make sure you get a few coats on there and give it plenty of time to dry. I found the best results with krylon came with many light coats.
Old Apr 24, 2008 | 08:39 PM
polpilot's Avatar
I did some peices in mine check out my gallery. i put up a post on how i did it, but i cant find it....
Old Apr 24, 2008 | 08:45 PM
since i cant sand the peices beforehand i was thinking of just applying an adhesion promoter first then painting
Old Apr 24, 2008 | 08:49 PM
polpilot's Avatar
I would do that and use a light sand... not to make it smooth but just enough to remove all the amorall.
Old Apr 24, 2008 | 08:55 PM
thats a good idea. im probably gonna test it on a small peice first just to see how well it will hold up
Old Apr 24, 2008 | 09:00 PM
polpilot's Avatar
That what i did to the center peice of my Expy console, i didnt want it smooth but still wanted it black and kinda shiney, i used krylon spray paint and clear make sure you let the claer dry atleast overnight. It seems to take longer to dry then paint.
Old Apr 24, 2008 | 09:10 PM
polpilot's Avatar
OH!!! make sur you take what yyou want to paint out of your truck.... i dont think i have to say it... but you never know
Old Apr 24, 2008 | 09:16 PM
do several layers of primer to build up the lower spots of the texture, then sand it smooth, then paint, and clear.
Old Apr 24, 2008 | 09:17 PM
italiano's Avatar
i painted my door panels and i first cleaned everything with dishwash liquid since it cuts grease and after it was totally dy i used adhesion promoter.and right after spraying adheion promoter spray the color.check my gallery for the door panels.
