Upper door panel removal
Old Apr 22, 2008 | 03:00 PM
SmokeyBear's Avatar
I'm thinking of tinting my windows, therefore I need the upper door panel to pop out a bit. I did this on my Crown Vic easily just by grabbing it and pulling out a bit but I don't want to try it on my truck unless it's confirmed that it can be done. So the short question is, can you just pull the top of the door panel out a bit (on all four doors since it's a Screw) to access more of the window?/
Old Apr 22, 2008 | 03:29 PM
Brandon Miller's Avatar
No you can't. It overhangs teh channel slightly. The door panels are easy to remove though.
Old Apr 23, 2008 | 09:01 AM
SmokeyBear's Avatar
Ok. so does anyone have the instructions on how to remove the door panel?
Old Apr 23, 2008 | 09:15 AM
Impact9's Avatar
try search
or
in short- you need a set of metrics. Pop the little cover plate off behind the handle. Pop off the arm rest switch panel and disconnect wires. Remove all the bolts and screws. Once it's loose lift straight up on the panel then pull out. There are L shaped catches that hold the panel on the door. The feed the door handle through the panel and your set.
course the guy that did my windows didn't need to remove the panels at all.
Old Jun 15, 2008 | 08:43 AM
sean46's Avatar
Does anyone know how to remove the window crank when removing panels?
Old Jun 15, 2008 | 08:53 AM
Copenhagen848's Avatar
Check my gallery for instructions on rear door panel removal if you need it.
Old Jun 15, 2008 | 11:15 AM
DARK KNIGHT08's Avatar
This may help.
https://www.f150online.com/forums/sh...d.php?t=334287
Old Jun 15, 2008 | 11:31 AM
sean46's Avatar
Thanks fellas! I think I can figure it out now.
